TF1260 stuff
Re: TF1260 stuff
ekalkici wrote: 03 Jun 2021 15:35 Thanks again Stephen, i read the infos there just wanted to ask here maybe to get some knowledge from another card user. One thing to ask you if i install a 33mhz crystal can i get 66mhz cpu speed by default. And will this affect other components speed on card (like rams etc..)
The cards were extensively tested by 10 people to produce that readme. All the data is there.
If you change the crystal you're pretty much on your own.. It probably wont even boot. I'm not even going to waste time on this. The clock multiplier was added so people wouldnt screw with the crystals.
hammer
Re: TF1260 stuff
Post by hammer »
alenppc wrote: 05 May 2021 14:47
GadgetUK164 wrote: 05 May 2021 14:36 No worries! It rocks at 62.5Mhz TBH =D I suspect the R4 cannot go much beyond that anyway!
It depends on the individual CPU... some can go as high as 85, some crap out at 75...
The normal silicon lottery.
Re: TF1260 stuff
I've checked StarStruck.. no issues for me here at any clock speed.
i'll post a video of it running on my TF1260 with release firmware in a bit.
There are intentional glitches in the demo but i dont see anything like what you see..
Are you running 2018 version of the demo? the 2006 version is buggy apparently.
Higgy
Re: TF1260 stuff
Post by Higgy »
As Stephen says, I also use Starstruck-Final. There was one glitch I noticed at the start of crawling robot, but it is fine.
I also tried Test Drive 2 and yes it is glitchy, but.... I was using v1.0:
version 1.2 (05.02.2020) done by JOTD:
- fixed the flickering bug on fast machines
- reenabled fast memory (now that the flickering bug has been fixed)
There is version 1.5 available. I will switch on my Win PC and update, but it's looking hopeful that it's due to the WHDLoad version.
Update: downloaded wrong version but tested 1.4 and no glitches. Added NOMMU and NOCACHE tooltypes. Might only need 1 of those.
ekalkici
Re: TF1260 stuff
Post by ekalkici »
Higgy wrote: 03 Jun 2021 18:05 As Stephen says, I also use Starstruck-Final. There was one glitch I noticed at the start of crawling robot, but it is fine.
Higgy thanks. I just tried NOMMU tooltype and graphic problem is gone. Now i added NOMMU to whdload global prefs file.
About starstuck demo problem , tomorrow will make more tests to find what the cause is.
EDIT : I was trying newest 2018 Starstruck-final verison and getting graphic problems (the one in my youtube video) Now i tried with 2006 party verison and no graphic problems. It's interesting to me that old version is problem free.
neilshak123
Re: TF1260 stuff
Post by neilshak123 »
Hi ekalkici, I'm getting the same weird glitching on starstruck-final too. Running a 2B MOBO, Rev 6 (from Chucky) and using Chucky's vanilla WB3. 1 disk image. Also get the same issue with supaduper's CWB disk that he included with my card. I have a 1D4 (both boards are recapped) so will test in that. Like you will do some more tests
Aardvark82
Re: TF1260 stuff
Post by Aardvark82 »
I get those starstruck glitches in 50hz and 62hz, but not in 75hz. Running on 1D4, WB3.1.4, and full rev6.
ekalkici
Re: TF1260 stuff
Post by ekalkici »
Aardvark82 wrote: 04 Jun 2021 03:11 I get those starstruck glitches in 50hz and 62hz, but not in 75hz. Running on 1D4, WB3.1.4, and full rev6.
I tihnk you mean cpu speed and in mhz. My cpu not stable 75mhz so i will try with other tf1260/rev6 cpu combination at my friend today and will report. Thanks for answers and nelishark1234 too.
Re: TF1260 stuff
Kick 3.1.4 is unsupported on all TF cards. I will check 50Mhz and 62 Mhz again.
The glitches you will probably have to live with them... or send your card back.
Re: TF1260 stuff
Just checked with kick 3.1 @ 50Mhz ... no issues.
Like i say i dont support 3.1.4. I will support 3.2 once i get the roms.
Return to “TF360”
