Those pins are part of the 16MHz oscillator circuit aren't they.
You don't have a dry joint on the ground or power of that chip do you? What do you get on pin 10?
BBC Model B No2. Will it live again!
Re: BBC Model B No2. Will it live again!
Pins 1-6 of IC43 form part of the 16Mhz master clock circuit. Continuity is good all the way through from the 16Mhz oscillator to IC6.stephen_usher wrote: 20 May 2021 11:13 Those pins are part of the 16MHz oscillator circuit aren't they.
With the clock triggered, the signal at pin 8 of IC6 matches that of pin6 at IC43, bar I can't tell what the frequency is, other than it looks like a very tight sine. Measuring at pins 7-4 of IC6 shows them to be different.
When the clock has been triggered and I'm seeing RAS activity, on pin 10 of IC43, I see the same as on pin 3 of the 6502A, as best as I can tell.
I also see activity on pins 37 & 39 of the 6502A.
BTW there is continuity between pin 11 of IC37 and pin 3 of 6502A. Also, IC 34 has been socketed and replaced and continuity to all pins and their next hop checked.
However, if I power on and leave the clock to it's own devices, then none of the above happens. I get no RAS, and see no signals in any of the places described above, so no CPU clocks either or at any of the pins on IC6.
I then trigger it and they all appear. I can boot touching pin 4/5 of IC43 and it will start with all signals in place.
What it feels like is that I am having to kick off the clock, and when it kicks off, it's running but really slowly. I need to hook it up to a TV and hold the probe on pins 4/5 whilst I boot, see if anything registers.
I was hoping to have picked up another working machine by now for comparison purposes, but I've missed out on about 2 or 3 now because the prices have just got silly. Some more coming up this weekend for me to go for.
BennehBoy
Clearly you just need to superglue your fingers to that chip :lol:
I'm not allowed superglue and my soldering iron time is limited, due to the burnings.......BennehBoy wrote: 20 May 2021 15:18 Clearly you just need to superglue your fingers to that chip :lol:
:dizzy:
It sounds like IC43, the 74S04, is having "issues".
This is why I asked it touching pin 10 on the chip helps (it's on a different clock line from the video chip) and checking the ground and power to that chip.
I've already replaced it. I have checked all the continuity between pins and their destinations.It's just decided to revert to doing nothing now and touching the IC43 pi4/5 no longer triggers the clock to start.stephen_usher wrote: 20 May 2021 15:52 It sounds like IC43, the 74S04, is having "issues".
Ho Hum
Probably the capacitors then. They're the things, along with the resistors, which set up the resonance.
Tomswork
Just a thought maybe you have a corroded solder joint in a via
Tom
Tom
They are on order :)stephen_usher wrote: 20 May 2021 17:22 Probably the capacitors then. They're the things, along with the resistors, which set up the resonance.
WhenI replace the caps etc I will check.Tomswork wrote: 20 May 2021 18:01 Just a thought maybe you have a corroded solder joint in a via
Tom
