slight tweak..
assign BERR = CPCS_INT & altrambuserr ? 1'bz : 1'b0;So at least that problem is figured out... Just need to figure out this odd dram corruption issue next :roll:
Top. :mrgreen:exxos wrote: 29 Apr 2021 11:32 @Badwolf
slight tweak..
EMUTOS says 64MB now :thumbup:Code: Select all
Note that -- as already stated on the list -- it is not required to have a bus error (though it certainly helps as you found out). If EmuTOS detected more than 64 MB of Alt-RAM before, there must have been memory that was writeable and readable above the 64 MB mark. For example, some TT-RAM cards for the TT don't generate a bus error, either, and they are still correctly sized by EmuTOS.exxos wrote: 29 Apr 2021 11:32 @Badwolf
slight tweak..EMUTOS says 64MB now :thumbup:Code: Select all
Isn't there IDE on the TF? Maybe addresses 0x1F00000 etc. are wrongly decoded to IDE...
error 55 238 $F00000 %111100000000000000000000
error 55 238 $F00400 %111100000000010000000000
error 55 238 $F00800 %111100000000100000000000
error 55 238 $F00C00 %111100000000110000000000
error 55 238 $F01000 %111100000001000000000000
error 55 238 $F01400 %111100000001010000000000
error 55 238 $F01800 %111100000001100000000000
error 55 238 $F01C00 %111100000001110000000000
error 55 238 $F02000 %111100000010000000000000
error 55 238 $F02400 %111100000010010000000000
error 55 238 $F02800 %111100000010100000000000
error 55 238 $F02C00 %111100000010110000000000
error 55 238 $F03000 %111100000011000000000000
error 55 238 $F03400 %111100000011010000000000
error 55 238 $F03800 %111100000011100000000000
error 55 238 $F03C00 %111100000011110000000000
error 55 238 $F04000 %111100000100000000000000
error 55 238 $F04400 %111100000100010000000000
error 55 238 $F04800 %111100000100100000000000
error 55 238 $F04C00 %111100000100110000000000
error 55 238 $F05000 %111100000101000000000000
error 55 238 $F05400 %111100000101010000000000
error 55 238 $F05800 %111100000101100000000000
error 55 238 $F05C00 %111100000101110000000000
error 55 238 $F06000 %111100000110000000000000
error 55 238 $F06400 %111100000110010000000000
error 55 238 $F06800 %111100000110100000000000
error 55 238 $F06C00 %111100000110110000000000
error 55 238 $F07000 %111100000111000000000000
error 55 238 $F07400 %111100000111010000000000
error 55 238 $F07800 %111100000111100000000000
error 55 238 $F07C00 %111100000111110000000000
error 55 238 $F08000 %111100001000000000000000
error 55 238 $F08400 %111100001000010000000000
error 55 238 $F08800 %111100001000100000000000
error 55 238 $F08C00 %111100001000110000000000
error 55 238 $F09000 %111100001001000000000000
error 55 238 $F09400 %111100001001010000000000
error 55 238 $F09800 %111100001001100000000000
error 55 238 $F09C00 %111100001001110000000000
error 55 238 $F0A000 %111100001010000000000000
error 55 238 $F0A400 %111100001010010000000000
error 55 238 $F0A800 %111100001010100000000000
error 55 238 $F0AC00 %111100001010110000000000
error 55 238 $F0B000 %111100001011000000000000
error 55 238 $F0B400 %111100001011010000000000
error 55 238 $F0B800 %111100001011100000000000
error 55 238 $F0BC00 %111100001011110000000000
error 55 238 $F0C000 %111100001100000000000000
error 55 238 $F0C400 %111100001100010000000000
error 55 238 $F0C800 %111100001100100000000000
error 55 238 $F0CC00 %111100001100110000000000
error 55 238 $F0D000 %111100001101000000000000
error 55 238 $F0D400 %111100001101010000000000
error 55 238 $F0D800 %111100001101100000000000
error 55 238 $F0DC00 %111100001101110000000000
error 55 238 $F0E000 %111100001110000000000000
error 55 238 $F0E400 %111100001110010000000000
error 55 238 $F0E800 %111100001110100000000000
error 55 238 $F0EC00 %111100001110110000000000
error 55 238 $F0F000 %111100001111000000000000
error 55 238 $F0F400 %111100001111010000000000
error 55 238 $F0F800 %111100001111100000000000
error 55 238 $F0FC00 %111100001111110000000000
error 55 238 $1F00000 %1111100000000000000000000
error 55 238 $1F00400 %1111100000000010000000000
error 55 238 $1F00800 %1111100000000100000000000
error 55 238 $1F00C00 %1111100000000110000000000
error 55 238 $1F01000 %1111100000001000000000000
error 55 238 $1F01400 %1111100000001010000000000
error 55 238 $1F01800 %1111100000001100000000000
error 55 238 $1F01C00 %1111100000001110000000000
error 55 238 $1F02000 %1111100000010000000000000
error 55 238 $1F02400 %1111100000010010000000000
error 55 238 $1F02800 %1111100000010100000000000
error 55 238 $1F02C00 %1111100000010110000000000
error 55 238 $1F03000 %1111100000011000000000000
error 55 238 $1F03400 %1111100000011010000000000
error 55 238 $1F03800 %1111100000011100000000000
error 55 238 $1F03C00 %1111100000011110000000000
error 55 238 $1F04000 %1111100000100000000000000
error 55 238 $1F04400 %1111100000100010000000000
error 55 238 $1F04800 %1111100000100100000000000
error 55 238 $1F04C00 %1111100000100110000000000
error 55 238 $1F05000 %1111100000101000000000000
error 55 238 $1F05400 %1111100000101010000000000
error 55 238 $1F05800 %1111100000101100000000000
error 55 238 $1F05C00 %1111100000101110000000000
error 55 238 $1F06000 %1111100000110000000000000
error 55 238 $1F06400 %1111100000110010000000000
error 55 238 $1F06800 %1111100000110100000000000
error 55 238 $1F06C00 %1111100000110110000000000
error 55 238 $1F07000 %1111100000111000000000000
error 55 238 $1F07400 %1111100000111010000000000
error 55 238 $1F07800 %1111100000111100000000000
error 55 238 $1F07C00 %1111100000111110000000000
error 55 238 $1F08000 %1111100001000000000000000
error 55 238 $1F08400 %1111100001000010000000000
error 55 238 $1F08800 %1111100001000100000000000
error 55 238 $1F08C00 %1111100001000110000000000
error 55 238 $1F09000 %1111100001001000000000000
error 55 238 $1F09400 %1111100001001010000000000
error 55 238 $1F09800 %1111100001001100000000000
error 55 238 $1F09C00 %1111100001001110000000000
error 55 238 $1F0A000 %1111100001010000000000000
error 55 238 $1F0A400 %1111100001010010000000000
error 55 238 $1F0A800 %1111100001010100000000000
error 55 238 $1F0AC00 %1111100001010110000000000
error 55 238 $1F0B000 %1111100001011000000000000
error 55 238 $1F0B400 %1111100001011010000000000
hmmm yep.. I had a lot of trouble trying to figure out the decoding syntax, eventually I got a line to work.. (but IDE interface isn't yet finished either)czietz wrote: 29 Apr 2021 11:53 Isn't there IDE on the TF? Maybe addresses 0x1F00000 etc. are wrongly decoded to IDE...
wire ide_access = ({A[23:16]} != {8'hF0});Well, that's of course problematic, as it matches all addresses that follow the pattern 0x??F0????, including alt-RAM addresses 0x01F00000, 0x02F00000, and others.
Well there's your problem. It doesn't take into account anything in the altram address range. Great shout, @czietz!exxos wrote: 29 Apr 2021 12:06czietz wrote: 29 Apr 2021 11:53 Isn't there IDE on the TF? Maybe addresses 0x1F00000 etc. are wrongly decoded to IDE...Code: Select all
wire ide_access = A[27:16] != 12'h0F0;
Right, so that came from the TF520.. It was the only line I could get to work to find IDE, but I think the 520 may have only had 4MB of RAM. or none.. can't remember..Badwolf wrote: 29 Apr 2021 12:18 Again, should be an easy enough fix:-
A29 will only come into play if you get up to 512MB RAM. A26 is technically enough, but by using A27 it's a nice three-hex-digit number.exxos wrote: 29 Apr 2021 12:39Right, so that came from the TF520.. It was the only line I could get to work to find IDE, but I think the 520 may have only had 4MB of RAM. or none.. can't remember..Code: Select all
Though should that be using up to A29 @Badwolf ?
