Got a Greaseweasle and now I'm clueless.
Re: Got a Greaseweasle and now I'm clueless.
You need to have a command prompt open and run it from there, it isn't a windows application. It won't work if you double click on it.
In the GW directory type: gw read mydisk.scp
mydisk.scp is the output file.
If you don't have a floppy connected it will complain, but it should still see the GW.
Cosmic Puppet
Post by Cosmic Puppet »
How do I get into the gw directory from here?
I'm very surprised you don't know how to do that.
Nevertheless, in that command prompt type:
cd downloads\greaseweazel-v0.26-win\greaseweazel-v0.26\
then press enter. You should change to that directory.
Type dir and press enter, it will list all the programs/files/directories in that directory, gw.exe should be one of them.
then type: gw read mydisk.scp
Like I said, without a FDD connected it will complain, but if you have correctly done the install as per the instructions, it should at least see the GW. Then when you have power to the FDD and it is connected it should work.
If it doesn't then you need to refer back to the software install instructions.
Cosmic Puppet
Even that doesn't work even though you can see I have it in the folder.
I'm sorry about this. I wrongly assumed that the exe would open the command line to let you begin typing commands.
try cd \downloads\greaseweazel-v0.26-win\greaseweazel-v0.26\
If that doesn't work just do each directory individuallly
So:
cd downloads
cd greaseweazel-v0.26-win
until you get to the bottom of the directory.
If you double click on a commandline executable that is expecting input it will just open and close.
Cosmic Puppet
rubber_jonnie wrote: 08 Apr 2021 16:05 try cd \downloads\greaseweazel-v0.26-win\greaseweazel-v0.26\
I've tried that already and I get "System can't find the path specified"
Typo on my part, it should be this: cd downloads\greaseweazle-v0.26-win\greaseweazle-v0.26\
Cosmic Puppet
rubber_jonnie wrote: 08 Apr 2021 16:10 Typo on my part, it should be this: cd downloads\greaseweazle-v0.26-win\greaseweazle-v0.26\
That's the same :lol:
I don't get it. I know the folder is in my downloads and yet it's still saying it can't find it. This is the stuff nervous breakdowns are mad of :lol:
In c:\users\Tony type dir and press return.
Post a screenshot.
Cosmic Puppet
Got it!
it was the "-win\" that was stuffing it.
