V1.5 booster & Blitterpatch
Hi,
I am thinking about to buy a V1.5 booster and put it into my Mega ST1 with 4 MB of Ram. What is not clear for me, what
I have to do with the installed Blitterpatch. Is that obsolet together with the booster?
BR
LaoMu
BR
LaoMu
Re: V1.5 booster & Blitterpatch
If you have a more "recent" blitter, then remove the patch and fix the trace under the CPU.. The patch is only needed on early blitters.
See bottom of this page...
http://www.exxosforum.co.uk/atari/last/MEGAST/index.htm
Hi,
thx for answering. I have a ST/SGS Blitter coded 8833. I assume that one do not need the patch, right?
Regarding the interrupted track....I think I just solder a small wire between the 2 points which
had been connected trough the track before.
Thanks LaoMu
Thanks LaoMu
It should be ok, I would remove the patch and give your machine a good try out first just to be sure.
Hi ,
I tried that out and the Mega ST runs fine without the blitter-patch. Before I order the booster 1.5 I have one question (one more).
I do need to order the booster 1.5 and the fast rom kit as well. But inthe moment there is no german dual tos chip in the shop.
Is this available again soon?
BR
Lao Mu
BR
Lao Mu
LaoMu wrote: Thu May 24, 2018 9:36 pm I tried that out and the Mega ST runs fine without the blitter-patch.
You need the fast ROM kit.LaoMu wrote: Thu May 24, 2018 9:36 pm I do need to order the booster 1.5 and the fast rom kit as well.
They should be in the shop in a few days, I just have not had chance to do more stock for them yet..LaoMu wrote: Thu May 24, 2018 9:36 pm But in the moment there is no german dual tos chip in the shop.
I would also suggest you get the mega buffer board..
https://www.exxosforum.co.uk/atari/store2/#0039
http://www.exxosforum.co.uk/atari/last/V ... MEGABUFFER
otherwise it may be unstable..
You are likely need some different resistor arrays for the mega, I can enclose them if needed..
I would apriciate if you can sell me the correct resistor arrays as well. I see a problem occuring with the buffer board.
This is installed in the shifter socket.....and I have a 4MB ram expansion installed there. Can this mounted together, as a sandwich ?
- Attachments
- IMG_1296.JPG (2.46 MiB) Viewed 12048 times
You should be able to plug the buffer into the socket you have there... it just buffers the clocks so I don't think there should be any problems..LaoMu wrote: Thu May 24, 2018 10:00 pm I would apriciate if you can sell me the correct resistor arrays as well. I see a problem occuring with the buffer board.
This is installed in the shifter socket.....and I have a 4MB ram expansion installed there. Can this mounted together, as a sandwich ?![]()
Ok then. Shall I order via the shop, or do You pack that all together with the resitor arrays and the Fast tos german. And tell me the final price.exxos wrote: Thu May 24, 2018 10:06 pmYou should be able to plug the buffer into the socket you have there... it just buffers the clocks so I don't think there should be any problems..LaoMu wrote: Thu May 24, 2018 10:00 pm I would apriciate if you can sell me the correct resistor arrays as well. I see a problem occuring with the buffer board.
I pay via paypal then..
Give me a few days to create the roms, then just order form my store, will send resistors free.LaoMu wrote: Thu May 24, 2018 10:13 pm Ok then. Shall I order via the shop, or do You pack that all together with the resistor arrays and the Fast tos german. And tell me the final price.
