TF CD32 Riser Revision 2 Build Guide.
TF CD32 Riser
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TF CD32 Riser Revision 2 Build Guide.
Post by arkadiusz.makarenko »
alenppc wrote: 23 Feb 2021 18:08 Do you mean if DB9 is plugged in at the same time as USB? There is no reaction whatsoever to DB9 mouse when the USB is plugged in. As soon as I unplug the USB the DB9 starts working.
Thnx, this excludes potential issue with PUNT
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
Does RTC work it should be detected in Amiga Test Kit?
~ Stanislaw Lem
arkadiusz.makarenko
Moderator Team
Moderator Team
I have added additional checks on IRQ routines and turned off caches and removed all gamepad routines.
So basically stripped back firmware to bare bones + RTC.
~ Stanislaw Lem
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Yes, the RTC is detected in ATK.
So just flashed this new one and it has the same effect, ATK still reports joystick buttons being pressed. If you switch to CD32 gamepad mode in port 1 in AmigaTestKit, it shows all buttons being pressed all the time.
arkadiusz.makarenko
Moderator Team
Moderator Team
alenppc wrote: 23 Feb 2021 19:48 Yes, the RTC is detected in ATK.
WEIRD!
RTC has like a "milion" requests with CPLD and ARM and if it counts time on screen this means that it reads values live... I will kick out CD32 gamepad support and leave even less.
Last one for tonight ?
~ Stanislaw Lem
alenppc
Moderator Team
Moderator Team
Post by alenppc »
RTC not detected now, mouse still crazy, and joypad buttons still show as being pressed! Very odd. Hopefully I will get the RET6 chip to try soon.
arkadiusz.makarenko
Moderator Team
Moderator Team
alenppc wrote: 23 Feb 2021 20:23 RTC not detected now, mouse still crazy, and joypad buttons still show as being pressed! Very odd. Hopefully I will get the RET6 chip to try soon.
Last question what crystal and caps on crystal do you have on? And what CD32 Revision?
Gampads shouldn't be deteced or keys pressed at all at this point. All code if removed for gamepads and joysticks.
Mouse + keyboard only.
Annoying is that I would find out what it is in 30min if I had it on my bench! (like whole set up)
~ Stanislaw Lem
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Using this as 25 mhz: https://www.mouser.ca/ProductDetail/774 ... D25M00000/
This as the 32k: https://www.mouser.ca/ProductDetail/815 ... 2.768KD2T/
The caps are the ones from Steve's assembly file, put directly by JLC. If you can't reproduce this with an 80 mhz crystal, I'll send you my riser plus 330.
arkadiusz.makarenko
Moderator Team
Moderator Team
alenppc wrote: 23 Feb 2021 20:31 Using this as 25 mhz: https://www.mouser.ca/ProductDetail/774 ... D25M00000/
<facepalm>
it doesn't matter as it works on both 060 and 020 ok!
Something like floating signal somewhere ...
~ Stanislaw Lem
alenppc
Moderator Team
Moderator Team
Post by alenppc »
So I got my ret6 chip today. To my surprise it looks like it made things worse! I think I will have to send you one of these boards to take a look at. EDIT: well, actually no, not worse. But same as RET7. So I guess it doesn't matter if we use RET6 or RET7 so that's good to know.
Return to “TF CD32 Riser”
