If there is output levels like than then its fine. I would actually wire that onto the ext audio pins of the riser and let them get mixed into the audio output from the CD32 RCA jacks.arkadiusz.makarenko wrote: 13 Feb 2021 10:07Don't know, I just looked at Raspberry Pi HIFI solutions.
Output is Direct Line Level 2.1-VRMS. Whatever it means.
Anyway I will try to understand it a little bit more.
Maybe there is enough data bandwidth to send decoded data back to Amiga and play it from there?
TF CD32 Riser Revision 3 Design discussion
- Admin sponsor
Re: TF CD32 Riser Revision 3 Design discussion
arkadiusz.makarenko
- Moderator Team
I have ordered dev board with this chip, and I will play with it if it is worth the effort.terriblefire wrote: 14 Feb 2021 09:43If there is output levels like than then its fine. I would actually wire that onto the ext audio pins of the riser and let them get mixed into the audio output from the CD32 RCA jacks.arkadiusz.makarenko wrote: 13 Feb 2021 10:07
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
I am starting new job tomorrow, so I packed CD32 for a while, as I got too distracted recently. I will put it on my bench again, when I settle in new post. Meanwhile I have set up my A1200 :D.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Oh i'll have to supply you something for that :)arkadiusz.makarenko wrote: 15 Feb 2021 18:17 I am starting new job tomorrow, so I packed CD32 for a while, as I got too distracted recently. I will put it on my bench again, when I settle in new post. Meanwhile I have set up my A1200 :D.
Users browsing this forum: ClaudeBot and 21 guests
