Granlunds FrankenSTein
agranlund
Re: Granlunds FrankenSTein
Post by agranlund »
exxos wrote: Tue Oct 27, 2020 9:46 am Oh cool. Would assume ST RAM wouikdnt be fast enough for it, or have enough RAM for it ? But paired with a 030 with 64MB RAM.. That would be pretty interesting ;)
I don't think memory bandwidth is an issue but the size certainly would be.
An 128kbit/s MP3 is just 16KB/s (or roughly 328 bytes per frame at 50Hz)
A simple approach for a player could load the entire MP3 into memory, but ideally it would stream it in chunks from disk->ram so it could work on 512Kb machines as well.
agranlund wrote: Tue Oct 27, 2020 10:10 am A simple approach for a player could load the entire MP3 into memory, but ideally it would stream it in chunks from disk->ram so it could work on 512Kb machines as well.
Yeah that could work also :)
agranlund
Post by agranlund »
Hahaha! My god... apparently I had the blitter socket facing down :dizzy:
Guess I have to rip up and redo the traces but I'm happy I spotted it.
Screenshot 2020-10-27 at 13.50.37.png (344.78 KiB) Viewed 4245 times
agranlund
Post by agranlund »
Well that was "fun".. maybe that'll teach me to tripple check before starting to put down traces :lol:
Screenshot 2020-10-28 at 18.29.59.png (164.11 KiB) Viewed 4209 times
Blitter socket now on the top layer where it belongs, and the Phoenix blitter should fit.
Screenshot 2020-10-28 at 18.29.12.png (302.72 KiB) Viewed 4209 times
agranlund
Post by agranlund »
Icky wrote: Fri Oct 16, 2020 9:53 pm
agranlund wrote: Fri Oct 16, 2020 9:33 pm Order sent, always exciting to find out how many bodge wires will be required :D
It's not a proper dev board until it has bodge wire :)
Nice work.
Ooops, forgot to route CAS0H so one was required :oops:
But it works!! :yay2:
After soldering the extra wires to the MMU I realised RAS1,CAS1L,CAS1R are in fact easily accessible from the top of the motherboard so I won't have to solder all four wires to the underside of the MMU socket :)
As far as I can tell I still need to grab MADR9 directly from the MMU pin though.
Found too many other little todo's for the next revision so I won't be soldering this one in place. I'll keep it sitting a little high in those ram sockets I added until I get the next rev ordered.
exxos approves the bodge wire :thumbup:
agranlund
Post by agranlund »
exxos wrote: Fri Oct 30, 2020 12:45 pm exxos approves the bodge wire :thumbup:
Haha I thought you might! :D
Nice idea, what did it cost roughly?
agranlund
Post by agranlund »
PhilC wrote: Fri Oct 30, 2020 4:05 pm Nice idea, what did it cost roughly?
Thanks! I'm actually really pleased with it :)
The board was €4.72 for the five of them, plus shipping and stuff so maybe €20 or so in total or ~€4 each in such low quantities.
For the RAM I just bought an old 8MB SIMM module off ebay :lol:
It was €3.33 and it had 4 x NN5118160AJ which I desoldered, that's enough for two boards.
The pin headers, 6 caps and 3 resistors I already had lying around.
Edit: since I'm not selling anything I guess the one RAM upgrade that eventually ends up being soldered in place in my machine will have costed the total cost of all boards + ram that I bought though :lol:
That's likely going to be the next revision unless I screw that one up somehow.
that's a pretty good price to upgrade your old ST
