TF CD32 Riser
kulamario
Post by kulamario »
excellent thx
go0se
Post by go0se »
terriblefire wrote: Thu Oct 15, 2020 8:41 am currently I have no solder station.
:o ... It's like Beethoven not having a piano! :)
go0se wrote: Thu Oct 15, 2020 10:08 am :o ... It's like Beethoven not having a piano! :)
The entire contents of my living room is currently in the room that my lab was in... while that room is redecorated and a stove is installed in place of the old gas fire.
matt020
Post by matt020 »
terriblefire wrote: Wed Oct 14, 2020 6:08 pm @arkadiusz.makarenko I have pushed all the changes to the branch. It includes a video buffer chip. Just needs checked over and we're good.
What happens in this case where a video buffer chip is used, and the end user then whacks on a VGA adapter with a buffer chip built in (AKA: the Commodore 23 pin to 15 pin adapter) ?
matt020 wrote: Thu Oct 15, 2020 12:26 pm
Its no different to attaching a TV to the 23pin adaptor.
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
Small progress with RTC.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Thu Oct 15, 2020 7:25 pm Small progress with RTC.
Sweet
arkadiusz.makarenko
Moderator Team
Moderator Team
terriblefire wrote: Thu Oct 15, 2020 7:37 pm
Sweet
I did try to start workbench and it is not very happy. I managed to start it few times, but it far from stable on boot time.
I think mechanism of pushing data need to be a little bit more sophisticated like you described.
Edit: I will try with fixed 100% valid output. Maybe it crashes on software side? I may be providing date section wrong.
~ Stanislaw Lem
chucky
Post by chucky »
Do not trust the RTC test. it is as buggy as its programmer..
I am working on 1.3 that will (hopefully) have that fixed.
arkadiusz.makarenko
Moderator Team
Moderator Team
chucky wrote: Fri Oct 16, 2020 9:33 am Do not trust the RTC test. it is as buggy as its programmer..
Do you think that bad RTC output can crash booting to Workbench?
~ Stanislaw Lem
Return to “TF CD32 Riser”
