Note: The names of the individual files in the archive start with A500* as this was derived from my A500 project, but they are the CDTV files
layers : 2
width : 83.37 mm
height : 45.66 mm
!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!!!!WARNING!!!
If you are installing an accelerator into the CDTV the motherboard will require some manual support on the right hand side as it is not supported by brackets in this area. Be sure to unplug the CDTV completely for a while to allow the PSU caps to discharge as you will need to place your hands close to the CDTV PSU to give the necessary support to the motherboard.
