TF536 Problems with Amiga and WHDLoad
- duncan.gibb
Re: TF536 Problems with Amiga and WHDLoad
I am pretty sure it's a full fat 030, with MMU, i can map the kickstart ROM, and see a massive speed increase. the screen draw speed improves 350%
Changing out the CPU for a known genuine ceramic RC50 OR RC33 and testing again would be my first port of call, but I appreciate not everyone has one of those lying around.duncan.gibb wrote: Fri Jul 03, 2020 10:43 pm I am pretty sure it's a full fat 030, with MMU, i can map the kickstart ROM, and see a massive speed increase. the screen draw speed improves 350%
- duncan.gibb
it's not socketed, and while i can tackle extremely small jobs, when it comes to this kinda thing, i wouldn't have a Scooby, the CPU had a label on topgo0se wrote: Fri Jul 03, 2020 10:49 pmChanging out the CPU for a known genuine ceramic RC50 OR RC33 and testing again would be my first port of call, but I appreciate not everyone has one of those lying around.duncan.gibb wrote: Fri Jul 03, 2020 10:43 pm I am pretty sure it's a full fat 030, with MMU, i can map the kickstart ROM, and see a massive speed increase. the screen draw speed improves 350%
- Attachments
- TF536.jpg (174.12 KiB) Viewed 4211 times
- arkadiusz.makarenko
- Moderator Team
This really looks a little bit like CPU doesn't like 50mhz.duncan.gibb wrote: Fri Jul 03, 2020 10:24 pm Thanks for that big man, i have tried 4 different CF card to IDE adapters, stuff that works faultlessly for ages in other Amigas. I can setup an OS in UAE, and then try it on the TF536 Amiga and i just get a black screen, and that's with EVERY CF to IDE adapter. I was advised to install MMULibs, as this would cure all ills, no change at all, occasional crashing now, with the odd bit of graphic corruption, i don't know what the CPU was originally, but it's not a ceramic package, so could be anything.
Personally I didn't manage to get plastic 030 to work with my TF536.
It is newly available card and I think we all still learn how to build it and properly test it, so unfortunately this kind of situations are unavoidable.
~ Stanislaw Lem
~ Stanislaw Lem
I’ve seen this happen with CPUs that can’t cope with the speed.
Unfortunately your only option is to replace the CPU.
Out of 50 CPUs labeled ‘33 MHz’, I only got like 5 working with the 536 and that’s why I started shipping them with a gold RC40C instead. And even in this case out of 12 I initially bought, one wasn’t up to the task.
- Admin sponsor
Who builds a TF board and solders the CPU down! Thats insane.
Gonnae no do that!
Gonnae no do that!
- duncan.gibb
I might add my name to the end of your list thenalenppc wrote: Fri Jul 03, 2020 11:56 pm I’ve seen this happen with CPUs that can’t cope with the speed.
it's a shame, for the 20 mins i had it stable, once i mapped the ROM into memory .... it was like VTEC kicked in.
VTECduncan.gibb wrote: Sat Jul 04, 2020 12:15 am once i mapped the ROM into memory .... it was like VTEC kicked in.
I have a ton of prebuilt cards... so that’s never a problem. The problem is that I am always waiting for CPU deliveries. Because I am never sure what kind of quality I am going to get I buy them in small batches and then end up waiting eternally.duncan.gibb wrote: Sat Jul 04, 2020 12:15 amI might add my name to the end of your list thenalenppc wrote: Fri Jul 03, 2020 11:56 pm I’ve seen this happen with CPUs that can’t cope with the speed.
Out of 50 CPUs labeled ‘33 MHz’, I only got like 5 working with the 536 and that’s why I started shipping them with a gold RC40C instead. And even in this case out of 12 I initially bought, one wasn’t up to the task.what's the waiting time like? i seen your thread on Amibay
Having said that I hope that I’ll get the next one in a week.
When he told you he soak tested it, what he meant was that he was soaked it in isopropyl for 6 hours
I know things happen, I will just send it back and get one `Soak tested` from Alen
