TF536 Memory testing Issue
I've built my TF536 board, can run frontier, sysinfo, stunt car racer for over 2hrs without a problem.
I've flashed it with the latest firmware on github.
I thought I would let amiga test kit do a few rounds of memory testing, but it gets to around 30MB then throws
up an exception error. Usually it gives a memory error and i've not seen this one before, so not sure what it means.
I've checked it with my USB microscope and cant see anything wrong.
I haven't checked it with diagrom yet, as it was 11 O'clock last night and thought I would wait till later tonight to
work on it again. I didnt want to start poking at with soldering iron again incase I broke it.
If anyone can offer any clue as to why amiga test kit gets this error, would be most helpful.
- Attachments
- exception.jpg (42.2 KiB) Viewed 4834 times
- sysinfo.jpg (77.1 KiB) Viewed 4834 times
- tf536.jpg (78.67 KiB) Viewed 4834 times
- Admin sponsor
Re: TF536 Memory testing Issue
Are you running AmigaTestKit from floppy? If not do that... otherwise it will be trashing the MMU tables.
Check in diagrom too
As Stepthen said it`s MMU conflicting with SYstest , it`s the same for the TF330 when I ran it ages ago, as you have run those demos for a good period I will say your build is good to go
Its running the latest version from floppy, as I haven't attached the IDE yet. I was just checking the
everything was working before I went further. I'll check with diagrom later on.
regards
regards
- Admin sponsor
I would check A25 is connected properly to the CPLDHomer79 wrote: Tue Jun 30, 2020 10:08 am Its running the latest version from floppy, as I haven't attached the IDE yet. I was just checking the
regards
I found my diagrom chip, I had to do a manual memory scan, as it didnt start scanning where the memory is located.
I did a fast scan, which completed all ok. Its doing a slow scan now, I shall let you know when its finished.
Are you sure your CPU is genuine? A reprinted Chinese CPU will crash spectacularly during memory testing.
I've never had any trouble with it in my TF530 & TF534 and thats always passed its memory tests.
Diagrom has tested around 54MB so far without reporting any problems. so its rather strange.
- Admin sponsor
DiagROM has gaps in its ram checks and never executes code from fastram.Homer79 wrote: Tue Jun 30, 2020 1:53 pm I've never had any trouble with it in my TF530 & TF534 and thats always passed its memory tests.
TF530 and TF534 have a completely different approach to the 536 which is basically a 330 for for the A500.
Hi, It completed the test absolutely fine, I can manually alter the fastram anywhere in the address range and no crashes happen.
I've done it around every address line value and its working fine. I will try it later on with an EC 030 and see if its the MMU
