TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
Re: TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
supaduper wrote: Sun Jun 21, 2020 8:41 pm
terriblefire wrote: Sun Jun 21, 2020 8:18 pm Just got an email from @chucky trying out @supaduper's latest image.
So when you say updates you mean BB2 updates?
And still the puzzle is that your test OS39 does work on mine all very puzzling
Yeah OS3.9 + BB1&2 and you get purple screen at startup.
We've dug deep into this now and i'm continuing to work on it.
EDIT: Specific setup is OS3.9 + BB1&2 + MMULib.
On my setup i have also got Mediator installed but that doesnt make a difference to the bootup.
Nothing else is installed on the card.
Good luck guys. Looking forward to seeing a working 1260 and 360
supaduper
Post by supaduper »
So I found an untouched OS39 with BB2 with all the updates among the many many Amiga images I have :), I will have a play with that later and see if we can get it to play ball :)
**EDIT
Okay so I have here OS39 + BB2 updates MMU libs ...And its all fully functional, so I will upload the image to you later Steve, its 4gb so will take a little longer :) for you and Chucky to try
pic below prooves its running with BB2 and MMU
TF360 OS39 BB2 MMU Pic.jpg (273.77 KiB) Viewed 5302 times
alenppc
Moderator Team
Moderator Team
Post by alenppc »
No issues running 3.9 on the 360 here using the image Steve sent me, although I suspect this might not be the BB2 version?
supaduper
Post by supaduper »
alenppc wrote: Mon Jun 22, 2020 1:52 pm No issues running 3.9 on the 360 here using the image Steve sent me, although I suspect this might not be the BB2 version?
Has he sent you the last one I sent him ? the one With BB2 updates ?
see the picture in the post above look at the Devs drawer BB2 update :)
alenppc
Moderator Team
Moderator Team
Post by alenppc »
supaduper wrote: Mon Jun 22, 2020 2:12 pm
Yes, it has the same files, and the version seems to be the same as yours. So I guess no issues then?
Exec is definitely updated, and no updates are skipped.
supaduper
Post by supaduper »
alenppc wrote: Mon Jun 22, 2020 2:17 pm
Yes bud that is a vanilla OS_39 BB2 with MMU so good news it works for you, just waiting for chucky and Steve to see if they have any joy with it
chucky
Post by chucky »
Still sadly purple screen for me :-(
chucky wrote: Fri Jun 26, 2020 10:05 pm Still sadly purple screen for me :-(
I am tracing through the OS 3.9 startup by hand on the Logic Analyzer... looking for why it fails.
EDIT: This may take some time.
I believe i have a complete trace of all memory accesses after reboot from the end of the colour bars to the point where it sets the purple screen...
This was a chore to do with an LA with a 4K buffer..
Basically I have a way i can programatically reboot the Amiga (mains power on/off via IP commands) and i have a networked logic analyser (which is programmable over TCP/IP). So i decided to write code to trigger on the error (3rd write of 0f0f to dff180 after power up) at the end of the buffer and work backwards... Writing a python script to parse the buffer, setup new triggers, reboot the Amiga and repeat...
Here is the output... its been weeks of effort to get this
capture_complete_clean.txt
(11.66 MiB) Downloaded 199 times
Remember this is instruction and data fetches not cpu execution addresses.
I need to figure out where this deviates from winuae.
Return to “TF360”
