Would you know what the approximate ambient temperature was during your testHiggy wrote: Sun Jun 14, 2020 10:02 pm just been using infrared thermometer.
After 3 060 demos back to back and at 75mhz I recorded max 40 deg on CPU. Most of cpu was 36
CPLD was 31 and 37 deg.
(this is with the case on and my little 5v fan running on the cpu).
The TF360 rev2 arrives
Re: The TF360 rev2 arrives
19-20 degrees ambient.
In have started a specific TF cooling thread in AMIGA Hardware. Just thought people would be interested in numbers.
My TF360 rev2 pcb has finally arrived today
WIll build it tomorrow
- Admin sponsor
Is it working?alenppc wrote: Thu Jun 18, 2020 8:49 pm My TF360 rev2 pcb has finally arrived todayWIll build it tomorrow
Works great on 3.1, but will 3.9 on Monday. Doubt the kids will let me do anything over the weekend...terriblefire wrote: Fri Jun 19, 2020 6:36 pmIs it working?alenppc wrote: Thu Jun 18, 2020 8:49 pm My TF360 rev2 pcb has finally arrived todayWIll build it tomorrow
Just a little TF360 update.
Apart from setting up Wi-Fi I have really just been watching 060 demos. The card seems to behave really well, I am pretty much always at 75mhz for the demos.
Probably I have had the machine lock up 4 times when running Cpuspeed but that is about it
I mostly boot no startup-sequence, setpatch, Cpuspeed and then navigate to the demos.
Thanks to all involved.
Is the Disable060 not implemented yet?
I just pulled off my jumper from my flying lead and got power/access light flickering. (was just going to test and also use CD drive).
I also got a Clockport RTC. AmigaKit have them slightly reduced at the moment.
I posted yesterday in the Topic about cooling that I had a crash yesterday with case on ( was not a full crash, the sound started to get out of sync then the video stuck on the demo). I've got my fan on the 060 so it might have been CPLDs as they felt toasty. But its not like we get 30 deg in the UK often, but might be more applicable to TF1260.
This is the board I'm terribly excited about.
My apologies to arrive late in the game on Exxos forum but I have few questions that could easily resume in one: is there a thread here which summarizes all the specifications of this beuatiful piece of art and technology that my CD32 is calling for?
Now my silly ignorant questions were:
- Is rev2 the latest one ? What motivations for the update ?
- I see clockport - is it working yet ?
- I see wifi module ? Really ? how ?
That beats the TF330 which I own (thanks AlenPPC!) by a 100 miles!!! What a great time to be alive and owning an Amiga !
I hope some good guys will be able to get one of these some day... and I hpe to qualify for that adjectives, even if I have to wait until 2030.
Thanks again, master !
- Admin sponsor
Its unlikely i'll ever do anything much more with this board. Certainly it will not be generally available.
I did the limited release for TF1260 because @chucky harassed me enough. There are three builders out there I trust to do my limited runs. Two of them arent interested much in the 360.
Likely what will happen is the board I have i will tinker until i get the CD Drive working and i'll install a Solas from @Daedalus and stick it under my TV.
Thanks Stephen, for your kind and detailed reply.
I forgot that the CD-Rom didn't work yet... which doesn't remove much from your fantastic creation (I've now read more in details the "TF360 Status" thread and all others related ones) but still is a serious issue for the little Amiga CD32.
I know how much Chucky had to "bother" you so few good guys could get a TF1260 to play with, and I hope that the only one builder who is interested in the TF360 will follow the same path.
Even if I don't have the same skills than most people on this very technical forum and can't help much, I at least have the same passion for our retro-machines.
I hope you'll break through the final technical issues soon... and hope to be lucky one day!
Wish you all the best, and peace of mind.
