EXXOS IDE V1.1 R1C BUILD & INSTALL INFORMATION
IDE, ACSI etc kits and products.
Re: EXXOS IDE V1.1 R1C BUILD & INSTALL INFORMATION
@JezC Can I suggest that you may want to get some longish 44 pin IDE cables, as it gives you a bit of flexibility when it comes to positioning of any drives you're going to use.
Post by JezC »
rubber_jonnie wrote: Mon May 18, 2020 4:27 pm @JezC Can I suggest that you may want to get some longish 44 pin IDE cables, as it gives you a bit of flexibility when it comes to positioning of any drives you're going to use.
@rubber_jonnie Good idea - did you find a reasonable source for them?
I'm wondering how long they may need to be now... :roll:
@JezC I bought 8 inch cables from eBay, plus a 2.5" one from exxos. He also has cheap CF adapters.
The short ones are more suited to the A1200.
Post by JezC »
@rubber_jonnie Great - I will ahe a look at those.
I think the only one I have 'spare' is the one from my defunct Falcon internal IDE drive & I'm hoping to re-use that with the CF card & adapter in the Falcon...in the meantime, it has an external 1GB SCSI drive connected :)
I've seen the bits in the store...just worried that I need to upgrade my version of HD Driver to work with CF cards (something like v4.52 I think) :roll: - and I probably need to find my original disc to be able to buy the upgrade at the reduced price :coffee:
Yeah, HDDRIVER is v11, so you're a bit behind!
PaulJ
Post by PaulJ »
JezC wrote: Mon May 18, 2020 5:17 pm I probably need to find my original disc to be able to buy the upgrade at the reduced price :coffee:
If you email I believe he keeps track of all customers names or just have your serial number. Your version may be as old as the Atari. :)
Post by JezC »
PaulJ wrote: Mon May 18, 2020 6:25 pm
:o :shock:
Yes, probably last updated it in the late 90s for the Falcon to work with a SCSI CD or something...
I think I bought it (and the upgrades) from System Solutions at an Atari show so I think he wants to see a photo of the original disc...I have a backup copy to hand but not yet found the original disc :? :roll:
dragmar
Post by dragmar »
Diode LED1 what voltage (3.3V or 5V)?
dragmar wrote: Tue Jun 09, 2020 8:57 am Diode LED1 what voltage (3.3V or 5V)?
5V is what I used IIRC.
dragmar
Post by dragmar »
IDE V1.1 R1C - LED 5V?
Do you also need to use PLD connections in this board?
Return to “HARD DRIVES”
