- arkadiusz.makarenko
- Moderator Team
As I didn't expect, not all keyboards are made equal. Mouse/Keyboard combo registers 6 buttons correctly as expected.
Ultra cheap ASDA and DELL keyboard can do only 4 buttons correctly.
I have slapped code which ignores error report, and just repeats previous recorded keys.
Depress button issue is non issue in workbench. In AmigaKit buttons appear white, but Shell just treat them as pressed for a second or so, and it just carry on. I though it will be registered as constant pressed. I think it may not be perfect, but it is bloody good enough.
I have pushed changes to repository. I think at this point it is ready to be tested.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Right i'm gonna give this a whirl.
A good test for the 'feel' of the keyboard performance might be with a pinball game like Pinball Dreams etc. See if it feels different from a normal keyboard AMIGA/cd32 set up.
- Admin sponsor
CD32 resets every time i press a key. Something isnt 100%
- Moderator Team
Damn. Which line is responsible for reset in cd32? Maybe it is not released after keypress, and Amiga 500 doesn't care about it.terriblefire wrote: Sat May 16, 2020 11:09 am CD32 resets every time i press a key. Something isnt 100%
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Keyboard controller does all the resets on the CD32. Keyboard init causes reset. Thats why when you plug in a keyboard it reboots.arkadiusz.makarenko wrote: Sat May 16, 2020 12:05 pmDamn. Which line is responsible for reset in cd32? Maybe it is not released after keypress, and Amiga 500 doesn't care about it.terriblefire wrote: Sat May 16, 2020 11:09 am CD32 resets every time i press a key. Something isnt 100%
- Admin sponsor
Checking we send these codes?terriblefire wrote: Sat May 16, 2020 12:13 pm Keyboard controller does all the resets on the CD32. Keyboard init causes reset. Thats why when you plug in a keyboard it reboots.
void amikb_startup(void)
uint8_t AMIGA_INITPOWER = 0xFD; //11111101
uint8_t AMIGA_TERMPOWER = 0xFE; //11111110
DBG_N("Enter\r\n");
// De-assert nRESET for Amiga...
amikb_reset();
amikb_direction(DAT_OUTPUT); // Default
mdelay(1000); // wait for sync
amikb_send((uint8_t) AMIGA_INITPOWER, 0); // send "initiate power-up"
udelay(200);
amikb_send((uint8_t) AMIGA_TERMPOWER, 0); // send "terminate power-up"
DBG_N("Exit\r\n")
https://github.com/gianlucarenzi/stalkb
- Moderator Team
That was I use.terriblefire wrote: Sat May 16, 2020 1:23 pmChecking we send these codes?terriblefire wrote: Sat May 16, 2020 12:13 pm Keyboard controller does all the resets on the CD32. Keyboard init causes reset. Thats why when you plug in a keyboard it reboots.
Best reference i have for Amiga keyboard controller is ...Code: Select all
// ************************** void amikb_startup(void) { uint8_t AMIGA_INITPOWER = 0xFD; //11111101 uint8_t AMIGA_TERMPOWER = 0xFE; //11111110 DBG_N("Enter\r\n"); // De-assert nRESET for Amiga... amikb_reset(); amikb_direction(DAT_OUTPUT); // Default mdelay(1000); // wait for sync amikb_send((uint8_t) AMIGA_INITPOWER, 0); // send "initiate power-up" udelay(200); amikb_send((uint8_t) AMIGA_TERMPOWER, 0); // send "terminate power-up" DBG_N("Exit\r\n") }
On my cd32 keyboard does work, but is feels a little unresponsive on Diagrom, but doesn't reset computer on pressed key.
Ctr+Alt+Del does work as reset...
Keyboard init is executed on arm start now.
I need to run normal os...
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Mine was crashing using DiagROM too. :/
- Moderator Team
I will push another version I removed reconfiguration of gpio to input, shortened clock pulses shortened data init singal a little etc. It is not as snippy as on A500, but does the job on my cd32.
- Attachments
- 20200516_203155.jpg (253.86 KiB) Viewed 3978 times
~ Stanislaw Lem
~ Stanislaw Lem
