If it was HS Then you need to comment one line related to ULPI clock enable. I will send yout exact line of code tomorrow.terriblefire wrote: Sun Apr 26, 2020 10:27 pmOk i'll get the basic amiga.c / amiga.h setup with a stock library and you can hack away after you're done rewriting.arkadiusz.makarenko wrote: Sun Apr 26, 2020 8:31 pm @terriblefire
I need to rewrite USB library, differences are quite substantial between devices, just copying bits didn't work.
I don't want to slow you down, if you can work on stock library then great, just create project with FS and HS HID USB, and I will replace library when it is ready. It may take me a little more time as expected.
One thing I did notice is that one of the USB ports turned on my usual mouse and one didnt. I presume this is part of the issue.
- arkadiusz.makarenko
- Moderator Team
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Honestly for right here and now i'll just use one USB port and let you extend it later.arkadiusz.makarenko wrote: Sun Apr 26, 2020 11:16 pmIf it was HS Then you need to comment one line related to ULPI clock enable. I will send yout exact line of code tomorrow.terriblefire wrote: Sun Apr 26, 2020 10:27 pm
- Moderator Team
Progress at last!
I love Meld, it saved be days.
I managed to get two devices with multiple interfaces registered. And I tested receiving data from one device from multiple interfaces.
Need to test if data is correctly received from devices, and complete middleware bit to get one point of access to different types of devices
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Great work.
- 8 Bit Dreams
- Moderator Team
Arek, one question,
is RTC already working?
- Admin sponsor
No nothing is working yet.. It doesnt talk to the amiga yet.
EDIT: Arek is focussing on the USB stack and middleware.
- Moderator Team
It is not on my to do list yet. I need to learn anything about power modes for this chip first
At this point I am battling with report parser for mouse on interface 1. Build in mouse report parser doesn't work (I assume it does only for mouse in boot mode), and my own parser doesn't read report size correctly.
It may be issue with one step before - reading hid descriptors for interface different than interface 0.
Build in functions can read them only for default interface -0, maybe I missed something when I was porting code to f722. This would cause that hid report descriptor for keyboard would be parsed as mouse report descriptor.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
You'll get therearkadiusz.makarenko wrote: Wed Apr 29, 2020 12:42 am It is not on my to do list yet. I need to learn anything about power modes for this chip first
Mwahahahahaha
- Moderator Team
Got it.terriblefire wrote: Wed Apr 29, 2020 12:49 amYou'll get therearkadiusz.makarenko wrote: Wed Apr 29, 2020 12:42 am It is not on my to do list yet. I need to learn anything about power modes for this chip first
Build in functions can read them only for default interface -0, maybe I missed something when I was porting code to f722. This would cause that hid report descriptor for keyboard would be parsed as mouse report descriptor.or else
Mwahahahahahaok lockdown is starting to affect me...
It was messed new ST HID Parser, I reverted to old library version, updated few bits and now it works.
https://github.com/arkadiuszmakarenko/TFRiserRev1F722
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Excellent work.arkadiusz.makarenko wrote: Wed Apr 29, 2020 9:22 am Got it.
