Modified TOS to remove resolutions limitation
General Discussion, STOS.
Smonson
Re: Modified TOS to remove resolutions limitation
Post by Smonson »
I learned another interesting fact which has probably been altering my conclusions a bit.
Under emulation in Hatari, the virtual shifter in RGB mode can be set to 0, 1, or 2 (and if it's 2, the screen is disabled so you can't see what's going on) but when it's set to use a mono monitor, it's read-only and set to 2 permanently, ignoring all writes.
Similar in Steem, except that in RGB mode the register is also only limited to values 0 and 1. 2 is not possible. Same as Hatari when emulating a monochrome screen: mode 2 only.
It's possible that it might work fine on a real machine, I'll attach the ROM file here in case a volunteer with the HDMI mod would like to test it.
I really want to make some progress on my H4 - especially since I'm isolated in my house to protect my immune-compromised fiancee from catching any random viruses that happen to be floating around - but I shipped all the hardware that I've bought to my work address, and the office has been shuttered until at least the end of the month! :headbang:
Great work @Smonson it works. Unfortunately I had a wobble on the video (not sure why - need to take a look) but you can see the effect here, all three resolutions without changing a cable.
EDIT: Flashy Clock is very handy to quickly put a TOS image on and boot.
Nice work.
Smonson
Post by Smonson »
Icky wrote: 17 Mar 2020 18:57 Great work @Smonson it works. Unfortunately I had a wobble on the video (not sure why - need to take a look) but you can see the effect here, all three resolutions without changing a cable.
Awesome! :yay2: Thanks heaps for testing it!
I'll go back over it tonight and relay my exact changes as I promised to do earlier.
I don't know what the sync wobble is but it's probably my fault :lol:
great stuff!
Wasn't the wobble down to that clock issue from wayyyyy back ? I'm not at home for a couple of days so can't test mine out :(
Smonson
Post by Smonson »
exxos wrote: 17 Mar 2020 23:34 great stuff!
Thanks Exxos! Yeah, I hope the wobble is just clock noise, at least we have a solution to that :D
Smonson
Post by Smonson »
Changes (offsets given are for TOS1.4 UK, MD5 036c5ae4f885cbf62c9bed651c6c58a8):
At 0xfc06e, in the level 4 autovector (VBL handler), bypass the mono monitor check:
     /* In colour modes: */
     btst #7,%d1                             /* Check mono detect */
-    bnes lvl4_vec_nochange                  /* No mono monitor --> skip */
+    bras lvl4_vec_nochange                  /* Always skip */
     movew #2000,%d0                         /* Delay loop */
lvl4_vec_delay:
    dbf %d0,lvl4_vec_delay
    moveb #2,%d0                             /* Set resolution to mono */
    bras lvl4_vec_chmode
addr_0702:
     /* In mono: */
-    beqs lvl4_vec_nochange                  /* Monitor is present */
     moveb %a5@(defshiftmod),%d0             /* Get default shifter mode */
     .short 0xb03c,0x0002                    /* cmpb #2,%d0 */
     blts lvl4_vec_chmode                    /* Default shifter mode compatible with colour monitor --> jump over */
At 0xfcb2b6, at the beginning of FindDevice(), redirect to a replacement implementation:
 _FindDevice:
-    movew #4,%sp@-
-    trap #14                                /* Getrez() - get current video mode */
+    jmp _FindDevice2
     addql #2,%sp
     moveb %d0,%d2                           /* Save the original resolution value */
     .short 0xb43c,0x0002                    /* cmpb #2,%d2 - current rez = mono? */
At 0xfd86ba, in desk_pref(), stop disabling the mode buttons:
-    movew #8,%a0@                           /* HIGH res button .ob_state */
+    movew #0,%a0@                           /* HIGH res button .ob_state */
      bras addr_186be
 addr_186a6:
     moveal %d7,%a0
     addal #346,%a0
-    movew #8,%a0@                           /* LOW res button .ob_state */
+    movew #0,%a0@                           /* LOW res button .ob_state */
     moveal %d7,%a0
     addal #370,%a0
-    movew #8,%a0@                           /* MED res button .ob_state */
+    movew #0,%a0@                           /* MED res button .ob_state */
 addr_186be:
     movew _gl_restype,%d4
     subqw #2,%d4
At 0xfefc00, in place of a bunch of extraneous ffffs, insert the new FindDevice() implementation
_FindDevice2:
    movew #4,%sp@-
    addql #2,%sp
    extw %d2
    moveal INTIN,%a0
    movew %a0@,%d0                          /* Get the requested res from INTIN[0] */
    cmpw #1,%d0
    bnes fd3_not_1                          /* Mode 1 (no change) not requested, continue here */
    tstb %d2
    beq fd3_low_pal                         /* Originally low, mode "1" now selected - go here */
    cmpb #2,%d2
    beq fd3_high_pal                        /* Originally high, mode "1" now selected - go here */
    bra fd3_med_pal                         /* Originally medium, mode "1" now selected - go here */
fd3_not_1:
    tstb %d2
    beq fd3_orig_low                        /* Originally low */
    cmpb #2,%d2
    beq fd3_orig_high                       /* Originally high */
fd3_orig_med:
    cmpw #4,%d0
    beq fd3_goto_high                       /* 4 = Switch to high res */
    cmpw #3,%d0
    beq fd3_med_pal                         /* 3 = Stay in medium */
fd3_goto_low:
    clrw %sp@-
    moveq #-1,%d0
    movel %d0,%sp@-
    movel %d0,%sp@-
    movew #5,%sp@-
    trap #14                                /* Setscreen(-1, -1, 0) - change to low res */
    lea %sp@(12),%sp
/* Set up 16-colour palette */
fd3_low_pal:
    pea paltab16
    movew #6,%sp@-
    trap #14                                /* Setpalette(void *pallptr) */
    addql #6,%sp
    moveq #1,%d0                            /* return 1 */
    rts
fd3_orig_low:
    cmpw #3,%d0
    beqs fd3_goto_med                       /* 3 = Switch to medium */
    cmpw #4,%d0
    beqs fd3_goto_high                      /* 4 = Switch to high */
    bra fd3_low_pal                         /* Stay in low */
fd3_goto_med:
    movew #1,%sp@-
    moveq #-1,%d0
    movel %d0,%sp@-
    movel %d0,%sp@-
    movew #5,%sp@-
    trap #14                                /* Setscreen(-1, -1, 1) - change to medium res */
    lea %sp@(12),%sp
/* Set up 4-colour palette */
fd3_med_pal:
    pea paltab4
    movew #6,%sp@-
    addql #6,%sp
    moveq #2,%d0                            /* return 2 */
    rts
fd3_orig_high:
    cmpb #3,%d0
    beq fd3_goto_med                        /* 3 = Switch to medium */
    cmpb #4,%d0
    beq fd3_high_pal                        /* 4 = Stay in high */
    bra fd3_goto_low                        /* Switch to low */
fd3_goto_high:
    movew #2,%sp@-
    moveq #-1,%d0
    movel %d0,%sp@-
    movel %d0,%sp@-
    movew #5,%sp@-
    trap #14                                /* Setscreen(-1, -1, 2) - change to high res */
    lea %sp@(12),%sp
fd3_high_pal:
    movew #1,palette
    moveq #3,%d0                            /* return 3 (high) */
    rts
Smonson wrote: 17 Mar 2020 21:11 I don't know what the sync wobble is but it's probably my fault :lol:
Not your fault @Smonson. Turns out its the stack sockets I have on the DEV motherboard to help with FPGA GLUE and MMU testing are causing the issue.
troed
Post by troed »
Amazing stuff! As you all have noticed I've been quite silent for the better part of the last half year* - but coming back to all these developments is pure joy.
I'll get this TOS into my doubleST and get back to playing with that and the HDMI board soonish.
edit: Oh, and of course we should port this mod onto the 2.06 codebase.
/Troed
*) Bought a house. Almost done with the renovation of a (huge) storage room into an awesome (retro) workshop.
Smonson
Post by Smonson »
Good to see you Troed!
With the doubleST, I think you rely on an AUTO utility to update the GEM screen parameters, right? You may want to do a further mod and update those in the ROM. I can tell you where they are.
I'm looking forward to seeing the pics of your epic workshop :D
Return to “SOFTWARE”
Users browsing this forum: ClaudeBot, trendiction [bot] and 0 guests
