Another thread just reminded me to post this link of where people in the UK can still get some really good leaded solder...
It is the stuff I have used for ages, and I daresay this is one of the best solders out there to use and it does not stink too bad either.
https://cpc.farnell.com/warton/solder-2 ... dp/SD00016
Leaded solder sources UK
Re: Leaded solder sources UK
I buy from Rapid Electronics. Their own brand 60/40 is pretty good.
https://www.rapidonline.com/rapid-solde ... el-85-0595
They also stock Warton Metals solders.
Rapid wouldn't allow me to easily buy the leaded solder like others found a few weeks back, but CPC do.
Thanks, will add that to the list of must buys. What temperature you set the iron to just out of curiosity?
350c I use for general stuff, or higher if its on a lot of copper...PhilC wrote: Tue Mar 10, 2020 10:26 pm Thanks, will add that to the list of must buys. What temperature you set the iron to just out of curiosity?
Tom
https://www.ebay.co.uk/itm/163775782319
This T4 solder paste is really good for the price, I've tried the cheap solder paste and it's far nicer to use
