Wizztonics TOS206 upgrade issue - SOLVED
Bikerbob
Post by Bikerbob »
So again.. some new hardware...
No find on the net anywhere so far. No instructions.. no docs or software.
At the moment this machine.. only the two chips shown... not sure if those are custom ROMS with both 1.04 and 2.06 on it. I am assuming.
Switch on back has a closed, and open.. not a double throw. SO I assume 1.04 is default, 2.06 is closed.
Anyway.. 1.04 - get a white screen and floppy access ... thats all.
2.06 I get the atari logo in the top corner, no floppy access and thats all.
Any help would be very welcome.
James
Maximilian
Re: Anyone have it? know it?
Post by Maximilian »
Have you tried asking Wizztronics for the manual?
http://www.wizztronics.com/ataricomputers.html
Bikerbob
Post by Bikerbob »
Yep, no response so far.
James
DoG
Post by DoG »
Do you have a diagnostic cartridge to test it with?
Bikerbob
Post by Bikerbob »
The computer.. yes! actually I do now!
I have the exxos cart. SO I will try that tonight anyway.. Thanks :) just brand new to me.. and I know its upgrade related, so never thought to try the cart.
James
Bikerbob
Post by Bikerbob »
This is what I got.. So T4-- Video Counter Error. The memory controller is not generating the correct addresses for the display.
I have a mega ST2 rev 1 board.. not sure where the MMU is .. it calls it a GST MMU.. but on a rev 1 is it that chip? anyone?
James
Bikerbob
Post by Bikerbob »
I have a C1001509 mmu.. I pulled it.. examined it.. and put it back in.. still no good.
DO I replace it with the same chip?? I read from exxos last upgrade IMP chips maybe no so good. Can i replace with a different mmu?
I have 3 other machines right now.. can I sub in another with this odd board? are the MMU interchangeable?
James
DoG
Post by DoG »
Do a RAM check on the diag cart. Does it say 'OK'?
Bikerbob
Post by Bikerbob »
Cant get to a ram check.
The red screen means it failed on boot. T4 is as I said.. I need to sub in another mmu I guess.. see if we get past this point.
Exxos.. what chips can I sub in for the C1001509??
James
Bikerbob wrote: Fri Nov 15, 2019 3:36 pm Exxos.. what chips can I sub in for the C1001509??
Would need to see a image of the RAM area. I have a load of RAM chips not in my store yet as well, just not got time at the moment to test them.
