STe dual TOS upgrade - 1.62 works fine, 2.06 does not
Upgrade or replace the ROM.
derkom
Post by derkom »
I just installed the dual TOS upgrade in one of the STe boards I am working on and I've run into a strange problem: TOS 1.62 boots perfectly fine, but TOS 2.06 gives four bombs after the memory test. Diagnostic software shows CRC good for TOS 1.62 and CRC bad for TOS 2.06. I have verified with the schematic that every solder is good. All three jumpers are set 2-3. I've inspected and cleaned the socket and ROM. Is there anything that could cause this aside from a corrupt ROM?
Re: STe dual TOS upgrade - 1.62 works fine, 2.06 does not
That normally happens when the floppy drive isn't connected.
derkom
Post by derkom »
exxos wrote: Tue Sep 17, 2019 4:51 pm That normally happens when the floppy drive isn't connected.
Hahah, okay. It's not. :lol:
Edit: Yup, that was it. Boots fine now. Diag check still fails though. I won't worry about it. :mrgreen:
Wire 2019-09-17 at 6_59 PM.jpeg (13.47 KiB) Viewed 4642 times
derkom wrote: Tue Sep 17, 2019 4:54 pm Hahah, okay. It's not. :lol:
:lolbig: :bravo:
czietz
Post by czietz »
derkom wrote: Tue Sep 17, 2019 4:54 pm Diag check still fails though. I won't worry about it.
Afaik, the STE diagnostic simply does not know TOS 2.06. (It even says so on the screen: "New version number.") Therefore, it doesn't know which ROM checksum to expect, either, and fails. However, TOS 2.06 has a built-in checksum test at boot. As long as you don't see any error messages there, the ROMs are fine.
derkom
Post by derkom »
czietz wrote: Tue Sep 17, 2019 5:16 pm Afaik, the STE diagnostic simply does not know TOS 2.06. (It even says so on the screen: "New version number.")
Yeah, that's kind of what I was suspecting, given the "new version number" text. With the floppy reconnected, it all seems good now. Time to reassemble. :D
Thanks exxos and czietz. :geek:
Return to “ROM UPGRADES”
