Fixing smd pads.
arkadiusz.makarenko
Moderator Team
Moderator Team
Fixing smd pads.
Post by arkadiusz.makarenko »
Hi
I have one board which I messed up a little.
I took few caps with pads. Now how would I go and fix it?
~ Stanislaw Lem
Re: Fixing smd pads.
Probably be a good idea to post images of your exact problem.
arkadiusz.makarenko
Moderator Team
Moderator Team
exxos wrote: Mon Aug 19, 2019 7:21 pm Probably be a good idea to post images of your exact problem.
Sorry I don't have this board just now.
It is Amiga 1200 board without three capacitor pads. I am slowly getting courage, knowledge and required equipment to fix it.
I was thinking to use UV solder mask to fix in place new cut pieces of copper which would be paid and a little bit of a trace. I am not sure if this would be strong enough to keep cap on place?
~ Stanislaw Lem
If you aren't too worried about originality then you could change the caps to a through hole type and solder it to the next good point?
go0se
Post by go0se »
arkadiusz.makarenko wrote: Mon Aug 19, 2019 7:58 pm
CW2500 will hold the new pad and trace in place reasonably well. Be sure to give it plenty of time to set i.e. significantly longer than the packaging suggests. It can be baked as well but that's not an effective substitute for time in my experience.
https://www.digikey.co.uk/product-detai ... ND/1929217
You can buy copper foil/tape to create the new pad and trace but most of the available copper tends to be too thick. A more effective method is to peel back a ground strip from an old PCB and use that as the basis for your pad+trace template. It can be tricky to get enough copper off the scrap PCB in one piece however with a few attempts you should manage to get a large enough section.
It's best to use good quality fine/medical scissors to create the pad and trace rather than a blade as fine scissors can be more exact when cutting difficult shapes and the blade tends to crumple and crush the copper layer as it's hard to support.
Clean everything with IPA and make sure everything is dry and free of contamination before you start.
Make a decent overlap between the new and old trace, remove the mask and scrape the underside of the new copper to give a good contact, tin and solder them before applying the epoxy. Continuity test your new pad then leave the whole assembly for several days to a week and don't be tempted to replace the cap too early.
The replaced cap can also be bridge glued to a neighbour if there's another suitable cap or component nearby to give a bit more stability.
Best of luck.
Edit: I probably should have mentioned to have a few attempts on an old scrap PCB to get the process down before letting loose on your A1200. Old flat screen TVs tend to have plenty of surface mount electrolytic caps for you to rip the pads off and practice repairing. You will have plenty of epoxy to spare so best to get it right first before letting loose on a classic Amiga! :)
kludge
Post by kludge »
I don’t know if this is blasphemy or not, but I wouldn’t bother with recreating the pads unless absolutely necessary. I would stick to patch wire.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
PaulJ_2.0
Post by PaulJ_2.0 »
kludge wrote: Mon Aug 19, 2019 10:46 pm I don’t know if this is blasphemy or not, but I wouldn’t bother with recreating the pads unless absolutely necessary. I would stick to patch wire.
I agree, I just use enamelled wire and run it off to either the trace destination or if it's easier, a bit of exposed trace. recreating pads is all well and good if you want to make it look all pretty, but it serves no real practical purpose.
go0se
Post by go0se »
PaulJ_2.0 wrote: Mon Aug 19, 2019 11:25 pm I agree, I just use enamelled wire and run it off to either the trace destination or if it's easier, a bit of exposed trace. recreating pads is all well and good if you want to make it look all pretty, but it serves no real practical purpose.
Using an Amiga in 2019 serves no real practical purpose, but yet, here we all are! :lol:
kludge
Post by kludge »
go0se wrote: Tue Aug 20, 2019 1:32 am Using an Amiga in 2019 serves no real practical purpose, but yet, here we all are! :lol:
That’s a REALLY dangerous statement on, what used to be, a dedicated Atari forum. You have to be careful with that shit :lol:
My lack of focus:
kludge wrote: Tue Aug 20, 2019 7:09 am
We can all agree that a ZX81 is a great doorstop though right? :)
Return to “ELECTRONICS”
