CPU 16MHz.
RAM 16MHz.
ROM 16MHz.
STF Remake - True 16MHz Mode
Re: STF Remake - True 16MHz Mode
With blitter running 16MHz.
In action.
In action.
Cyprian
Nice figures.
what about using as Reference ST with the blitter enabled?
http://260ste.atari.org
You would just end up with the same benchmark as this one... https://www.exxosforum.co.uk/forum/viewt ... f=42&t=566Cyprian wrote: 07 May 2019 10:21 Nice figures.
Cyprian
I see there "Reference" --> "BLITTER NP". If I understand it correctly, you compare your accelerated ST with the blitter with figures from ST without the blitter.exxos wrote: 07 May 2019 12:15You would just end up with the same benchmark as this one... https://www.exxosforum.co.uk/forum/viewt ... f=42&t=566Cyprian wrote: 07 May 2019 10:21 Nice figures.
Correct.Cyprian wrote: 07 May 2019 16:20 I see there "Reference" --> "BLITTER NP". If I understand it correctly, you compare your accelerated ST with the blitter with figures from ST without the blitter.
Cyprian
ok,
would be cool to see figures where both STs "Reference" and "System" have "BLITTER Enabled""
Found a blitter file, but TOS206, so some % difference will be down to TOS..
Realistically, all the figures should be 200%. My workings were confusing things earlier so removed them..
16MHz system is literally a x2 system. So all scores being 100% for a reference machine with blitter, x2 them, and its 200% as shown.
In terms of reference 8MHz ST with blitter, it gives about 500% on blitting, so x2 that is 1,000%.
It is pretty impressive when you compare it to the 030/32 in the Pak. I'd love to see what scores we would get with your 50mhz cpu with the 16mhz mod,really going to be impressive.
Cyprian
looks impressiveexxos wrote: 07 May 2019 17:00 Found a blitter file, but TOS206, so some % difference will be down to TOS..
thanks
PhilC wrote: 07 May 2019 17:32 It is pretty impressive when you compare it to the 030/32 in the Pak. I'd love to see what scores we would get with your 50mhz cpu with the 16mhz mod,really going to be impressive.
would be cool to have that True 16MHz Mode with Pak or TerribleFire
