Redhawk668's TF534 build.
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
kludge
Re: Redhawk668's TF534 build.
Post by kludge »
Crap, I feel for you. :(
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
redhawk668 wrote: Thu Apr 11, 2019 1:03 pm It seems that I f*cked up my TF534 build..
Don't give up!
Choose lower temperature next time - 320-330° should be really enough...
redhawk668
Post by redhawk668 »
So, removed most of the parts of my failed TF534 board and soldered them on a new board. Went allright, only the large CPLD did not come off properly :(, had to order a new one + passives, resistors, etc.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
8 Bit Dreams
Moderator Team
Moderator Team
You need a preheater to remove parts from a 4-layer board, because inner layers obsorb heat, increase temperature will destroy cpld..
A cheap 17€ smartphone display separator will do the job
Regards,
Viktor
8 Bit Dreams wrote: Mon Apr 15, 2019 12:40 pm A cheap 17€ smartphone display separator will do the job
where are you seeing a 17€ preheater?
8 Bit Dreams
Moderator Team
Moderator Team
have bought one on www.aliexpress.com
Something like this will do the job:
https://de.aliexpress.com/item/LCD-Heiz ... e7d99ff-34
pay 35€, and You will get one with vacuum pump that holds cell phone in place, so You can separate broken glass easily :idea:
redhawk668
I am getting back in this project, I've put it on hold for a while, but with new PCB's and some new components I will build a new one. I will use the 68030/68882 combo from my TF530. This time it will result in a working TF534.
Return to “TF534 (OBSOLETE)”
