kludge’s TF534 build
- Admin sponsor
Re: kludge’s TF534 build
I just added an open board view file for the TF534 to the github page.
https://github.com/terriblefire/tf534
Note by default it opens on the bottom of the board.
Nice! Thank you!terriblefire wrote: Thu Mar 28, 2019 2:52 pm I just added an open board view file for the TF534 to the github page.
Got this today. Might also help. Maybe.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
Beeped my way throug the CPLDs, RAM, buffers and resistor networks, and can’t find any shorts.
Next I will try to work my way through OBV to see if somethings not connected right. But that’s for another day.
My lack of focus:
My lack of focus:
- Admin sponsor
try this firmware
https://www.dropbox.com/s/icxg3d8a2rbov ... g.zip?dl=0
I havent tested it but it should make the TF534 think the RAM is already configured so the OS will not try to allocate it to the system pool.
Then you should be able to diagnose if the issue is IDE or not... and finally use
http://aminet.net/package/util/cli/AddMem
do
ADDMEM START 40000000 TO 40400000 PRI -100
this will make the fastram low priority and not get code run in there . You should then be able to load systest from a cli.
do
Perfect, thanks! The wife will have to do without my company in front of the TV tonight as well
My lack of focus:
My lack of focus:
That didn't work out as planned. Wish me luck tomorrow!kludge wrote: Fri Mar 29, 2019 9:04 am Perfect, thanks! The wife will have to do without my company in front of the TV tonight as well![]()
My lack of focus:
My lack of focus:
Hi TF,terriblefire wrote: Fri Mar 29, 2019 7:57 am try this firmware
do
This firmware now works for me 3.1 boots with IDE , no issues
Next step with addmem START 40000000 TO 40400000 PRI -100, @ the moment I press enter ,and gives a softwarefailuer and reboots.
Will try to resolder/reflow all the ram chips..
Thanks a lot for this nonautoconfig firmware ...,Very helpfull
- Admin sponsor
No Problem,
I sometimes forget that I do this alot when bring up boards... hack firmwares to give me info.
Nice Station you have there,seems you have big plans aheadkludge wrote: Thu Mar 28, 2019 3:16 pmNice! Thank you!terriblefire wrote: Thu Mar 28, 2019 2:52 pm I just added an open board view file for the TF534 to the github page.
I needed a hot air station and thought that I could use an extra soldering station as well, so I bought a comboJustme14 wrote: Fri Mar 29, 2019 10:14 pm Nice Station you have there,seems you have big plans ahead!
My lack of focus:
My lack of focus:
