TF330 Akiko Rev 0 Issue (SOLVED)
68030 + SDRAM + IDE
alenppc
Moderator Team
Moderator Team
Re: TF330 possible issue?
Post by alenppc »
terriblefire wrote: Wed Mar 13, 2019 12:02 pm A quick email exchange with Toni Willen..
The ROM only checks for CAFE not the COCA...
@alenppc can you check address $B80000 on the ReV0 please with DiagROM?
Sure, but I don't know if I can get round to it before this weekend.
alenppc wrote: Wed Mar 13, 2019 12:53 pm
No worries. I suspect we will see C0C0CAFE for a rev0.
I’ll maybe slap together a tool to check.
go0se
Post by go0se »
Currently checking all CD32s that I currently have access to [4] for the revision 0 chip. I have a CD32 diagrom sitting here should I stumble across one.
Will update later on.
Here is a program i knocked up to check Akiko revision.
https://github.com/terriblefire/terribl ... takiko.zip
Its in ADF and Exec form. Simply run the testakiko binary in AmigaOS (no WB needs loaded)
go0se
Post by go0se »
All four are revision A here unfortunately/fortunately.
supaduper
Post by supaduper »
I just bast...ized Akira`s systest iso and put testakiko on it, tested and it works.
Just unzip the attatched file burn the iso, then cd at the prompt it will show CDTV_test dir, then just type testakiko hit Return and it will show what version you have
Akiko test.zip
(42.95 KiB) Downloaded 210 times
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Unfortunately the result is the same on the Rev 0, still reads it as 0xC0CA
supaduper
Post by supaduper »
Hopefully Steve will find what register the Rev 0 is stored in when he gets that Mobo and can then ammend his test software
Very odd that CBM didnt have a different verison for the chip. They were usually good at this sort of thing.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Consoldering the CD32 was hastily built as a company saviour they probably didn’t do the usual diligence. Maybe it’s not possible to detect different revisions via software.
Return to “TF330”
