TF330 Soft Reboot Issue (SOLVED)
- Admin sponsor
Re: TF330 Soft Reboot Issue
OK i have further tracked down this one..
If you watch the 020 during reboot...
vs the 030 at the same code..
Basically something is pulling the reset line up.
I guess a new revision of board would fix this by "breaking" the reset lines but i'll stick the analog scope on it and see whats going on next.
- Admin sponsor
Found the issue..
CD32 has a reset in and reset out. Bugger.
- Admin sponsor
OK here is the mod to fix... i tested it.
- Admin sponsor
And the fix works..
Fix done , Fix confirmed working with patch and tested with OS that requires to reboot and to insert modules,
Just a tip to people doing the patch, put the patch wire as close to the edge as you can otherwise the connector will push it off or worse take some of the pad with it ! , I use Kapton tape to stop the solder flowing all down the pad as this too can cause problems also
And I will glue the wire down
thanks for the fix Steve and your hard work
- Attachments
- TF330 patched.JPG (179.52 KiB) Viewed 5726 times
- GadgetUK164
Great job working out the issue! And the fix is nice and easy so not the end of the world at all =D Always amazed at how quickly you design (and fix) these boards. Incredible
If the order can't be amended and the 50 Rev2 boards do end up arriving from China, put me down for 4 anyhow to recoup some of your £ outlay..
I enjoy a good Kynar patch wire project, gives the board that authentic 80's look!
- 8 Bit Dreams
- Moderator Team
- GadgetUK164
Likewise! I don't mind building 4 of these and doing the mod to them.go0se wrote: Sun Feb 03, 2019 5:51 pm If the order can't be amended and the 50 Rev2 boards do end up arriving from China, put me down for 4 anyhow to recoup some of your £ outlay..
I enjoy a good Kynar patch wire project, gives the board that authentic 80's look!![]()
I confirm the fix is working. Cutting the trace is a bit tricky, you need a very sharp knife but it works.
