Hi All,
Does anyone (preferably in the UK) have a broken, busted or pillaged STF/M motherboard?
I'm specifically looking for the cartridge port, the 2.4...mhz oscillator and the other ports.
I don't want to buy a working one as that would be another working ST then killed off to make this STF board up. (already killed off one STFM with dodgy memory, when I made the last one.)
I also still have the ports on my broken existing STF Remake but am hoping not to use those as I'd like to keep that board as complete as possible for when I finally fix it.
Wanted - Broken ST Motherboard or Cartridge port
Re: Wanted - Broken ST Motherboard or Cartridge port
I can send you a cart connector + osc ...
I half recall buying some new oscs a while ago :shrug: I lost track..
That would be cool. will be ordering some stuff from your store in a bit. How much would you like for them?
If your doing a order, will just put um in the box for you.. just make a note on checkout to include other bits...Forgottenmyname wrote: 13 Dec 2018 20:21 That would be cool. will be ordering some stuff from your store in a bit. How much would you like for them?
Ok cool thanks
Users browsing this forum: ClaudeBot, Qwantbot and 1 guest
