Nope, it's not, I don't think I'd be winning any races at the mo..... Maybe the one for the worst memory..... Just using your posts here as inspiration to get the enterprise working properly and with some nice upgrades.stephen_usher wrote: Sun Jul 26, 2026 12:52 pmIt's not a race.PhilC wrote: Sun Jul 26, 2026 12:26 pm I've ordered the PCBs for the floppy interface and a ram upgrade that uses an AS6C4008-55PCNand a 16V8B which I have in stock here already.
So ive got a bit of catching up to do @stephen_usher but I shall get there in the end.![]()
General Stuff(tm)
Re: General Stuff(tm)
Yay! I have games to play on the Enterprise...
Most of them are hacked ("converted") versions of Spectrum games though... Which don't always work correctly, and often switch into an HDMI non-compliant video mode, so I have to switch to RF.
Some are hacked CPC games... Which look a lot better.
Then there is the very good software based Amstrad and Spectrum emulators though, which run full speed...
Then there are the few native games, such as the port of Yoomp, which look and sound very good.
So, this was the hacky version...
And now that the 74LS240 and 22V10 have arrived, the proper version...
And now begins the task of designing a case for it.
I'm going to have to read through your and @PhilC's Flan stuff before mine arrives
I am awaiting a batch of 5 RGB2HDMI boards so one of those will no doubt see service in it.
It's analogue RGB, so make sure that you get the correct daughter board for the RGB2HDMI.rubber_jonnie wrote: Mon Jul 27, 2026 3:14 pm I'm going to have to read through your and @PhilC's Flan stuff before mine arrives
I believe it is, but I will check. Regardless I plan to use or sell the PCBs myself so If I have ordered the wrong one I can just order some more.stephen_usher wrote: Mon Jul 27, 2026 3:18 pmIt's analogue RGB, so make sure that you get the correct daughter board for the RGB2HDMI.rubber_jonnie wrote: Mon Jul 27, 2026 3:14 pm I'm going to have to read through your and @PhilC's Flan stuff before mine arrives
If you're prepared to wait for delivery about a week to ten days you can get stuff from JLCPCB very cheap, my RGB2HDMI boards came out under £5 with delivery.
First iteration of a case for the floppy interface done. Needs a bit of work to the top half, then I can work on the "floppy hat" to fit on top containing a Gotek drive.
Very nice.stephen_usher wrote: Mon Jul 27, 2026 10:13 pm First iteration of a case for the floppy interface done. Needs a bit of work to the top half, then I can work on the "floppy hat" to fit on top containing a Gotek drive.
The first full prototype of my case with the "floppy hat" unit on top...
Very nice indeed.stephen_usher wrote: Thu Jul 30, 2026 11:09 pm The first full prototype of my case with the "floppy hat" unit on top...
