Hissing and whistling in the STe audio output
Re: Hissing and whistling in the STe audio output
@exxos: that's bad news, hoped to get one. Could you also add list of components to pcb thread? Resistors are decipherable from photos, but capacitors not. Thank you..
They are in the BRD file..nokturnal wrote: Mon May 09, 2022 6:16 pm @exxos: that's bad news, hoped to get one. Could you also add list of components to pcb thread? Resistors are decipherable from photos, but capacitors not. Thank you..
There are only 2.2uF and 10K resistors anyway.
Just wanted to add that I installed the STe DAC noise PCB on a TT tonight, it certainly did reduce the whiney noise that was present. Not entirely removed of course. But a large percentage better.
Photo of installation:
For the record: every single STE I've ever owned has had a very clear issue with noise, which is sometimes a little bit like listening to an old modem: you get used to the typical noises, and notice when something isn't right!
Still, I installed the beta audio fix into one of my STEs recently. I don't mind saying that I could not get the soldering method with the pins to work for me at all, so instead I chopped the legs off some spare LEDs and soldered those individually to the chips, and they were malleable enough that it was easy to then get the holes on the little fix board aligned and soldered.
For the sake of recording the impact, I tried to grab some audio out before the install and after under difference workloads (gembench, field diagnostics, Faster from FDD and HDD, and Gembench at 32MHz (via the exxos booster)
For the sake of recording the difference, here's before:
and here's after:
and here's after:
Cool. The original diagnostic cart test is crazy! Odd it only really starts beeping when it's hammering the display! I thought it was any access to RAM would cause the issue.. But seems much worse when it's changing the display.
Is it just me or is it actually quieter in 32mhz mode?
- BlankVector
That's amazing! No more noise.stween wrote: Mon Jan 26, 2026 2:05 am Still, I installed the beta audio fix into one of my STEs recently.
I have the very same issue in my STE: I can hear the data when it passes on the bus. I definitely should try that.
I would like to understand what you did precisely.stween wrote: Mon Jan 26, 2026 2:05 am I don't mind saying that I could not get the soldering method with the pins to work for me at all
Your goal was to try the fix presented at the very top of this thread, right?
And instead of using some wires, you just used spare LEDs legs, as it's equivalent?
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a color pixel in assembly language on Atari ST.
I just realised @stween posted in the wrong thread... It should actually be this thread.. viewtopic.php?t=643
Both fixes were better documented on my website
https://www.exxosforum.co.uk/atari/last ... /index.htm
My bad; I searched and I guess I saw the prior post about the audio fix in a TT. Can you or a mod move the posts?exxos wrote: Mon Jan 26, 2026 12:54 pm I just realised @stween posted in the wrong thread... It should actually be this thread.. viewtopic.php?t=643
Yep posts moved.stween wrote: Mon Jan 26, 2026 2:14 pm My bad; I searched and I guess I saw the prior post about the audio fix in a TT. Can you or a mod move the posts?
