I think your on the wrong point on the SDRAM..
You probably should upgrade to the latest ROM version as well.
coonsgm
Re: REV 3 - REV 5 - The beginning (ST536)
Aha! I miscounted the SDRAM pin....it was the 11th. Fixed. Now I just need to for the the new AT27C4096's to get here faster....4 on order from Digikey.
Have you tried booting with the ROM you have as it should still pass TT RAM test as a minimum?coonsgm wrote: 30 Nov 2025 03:22 Aha! I miscounted the SDRAM pin....it was the 11th. Fixed. Now I just need to for the the new AT27C4096's to get here faster....4 on order from Digikey.
coonsgm
See below images the system freezes just after copying the ROM to TT RAM. It doesn't make it to the TT RAM test. The second image is the error message when trying to boot EmuTOS 1.4. It recognizes 60mb of "Fast RAM".exxos wrote: 30 Nov 2025 10:41Have you tried booting with the ROM you have as it should still pass TT RAM test as a minimum?coonsgm wrote: 30 Nov 2025 03:22 Aha! I miscounted the SDRAM pin....it was the 11th. Fixed. Now I just need to for the the new AT27C4096's to get here faster....4 on order from Digikey.
coonsgm
I did make certain I have continuity between the correct PLD pin and SDRAM pin and that there aren't any bridges on the PLD (from the remove and replace with the 288)
Is the floppy drive connected? I've seen it lockup at that point as is when it accesses the floppy drive next.coonsgm wrote: 30 Nov 2025 12:35 See below images the system freezes just after copying the ROM to TT RAM. It doesn't make it to the TT RAM test.
Weird.. Don't know why the address is right at the top end. Nothing should be trying to access that high up.The second image is the error message when trying to boot EmuTOS 1.4. It recognizes 60mb of "Fast RAM".
It makes me wonder if EMUTOS stops checking for ram when it hits bus error or it keeps trying the whole address range? If that's the case, it would corrupt the ROM shadow in ram. Maybe someone knows?
coonsgm
Yes, the floppy drive is connected, but IDE is disconnected.exxos wrote: 30 Nov 2025 12:51 Is the floppy drive connected? I've seen it lockup at that point as is when it accesses the floppy drive next.
Should be fine at that...
Looks like TTram is copying fine now which is good..
Have you tried the 536 in a H4 or H5 and make sure you have 5.2v on the 5v rail on the PSU.
coonsgm
I've tried in both the Mega ST and the H5. Same results. I boosted the voltage to 5.21v, same result.
Could the SDRAM been damaged by my previous botched connection to the pin next to the correct one?
I don't think so.. It would have shorted the clock chip enable to the clock, chip enabled is low driven by the PLD.. It wouldn't have passed ROM copy if the SDRAM was toast.coonsgm wrote: 30 Nov 2025 13:03 Could the SDRAM been damaged by my previous botched connection to the pin next to the correct one?
You definitely used the beta1SS firmware?
I don't know what else it could be..
