:lol:
Next to the IC near the left..Where? :-| My eyes clearly aren't good enough
BTW I will PM you the firmware page, you will probably need that ;)
:lol:
No idea where your looking ?
First picture, just above U1, that corner pin looks different from the rest...and there are a couple of others a little to the left of those.
Yeah 3 headers missing the top part for some odd reason. Never seen that happen before. The though-hole part looks fine. So shouldn't cause any problems :hide:JezC wrote: 04 Sep 2025 16:03 First picture, just above U1, that corner pin looks different from the rest...and there are a couple of others a little to the left of those.
I will PM you the firmware page.. no German yet. I've not fixed some bugs in TOS yet, so need to do that before building any others..Miri wrote: 06 Oct 2025 17:14 @exxos: I think, I may need some CPLD firmware *.jed file and a modified TOS2.06 image file (German, pleeaase !!) now. :swave: :coffee:
I don't think that will work. You need to use the ST536 ROM.Will the current CPLD firmware allow for a boot from 192k ROM on the mainboard (Like TF536 with KAOS or EMU Boot), if the ST536 EPROM is not equipped ?
You can't.. the original ST536 has a 144 PLD, later builds now use the 288.. This is to bring it in line with the STE build and fixes. My new TOS build won't work with the original 144 logic anyway.What happens, if I put my 'proven' TF536 firmware on it ? (Still same/compatible pinouts on CPLD?) :fire: :hide:
Not sure I follow.. maprom isn't included anyway. Its to complicated and nobody knows how it works or has any maintainers, it's why I am moving away from it.coonsgm wrote: 07 Oct 2025 11:58 Exxos, when you eventually update the modified TOS, would you be able to build one without maprom?
Sorry, I meant simply copying ROM into TTram.exxos wrote: 07 Oct 2025 12:47Not sure I follow.. maprom isn't included anyway. Its to complicated and nobody knows how it works or has any maintainers, it's why I am moving away from it.coonsgm wrote: 07 Oct 2025 11:58 Exxos, when you eventually update the modified TOS, would you be able to build one without maprom?
The current ST536 TOS is modified to fix cache related issues. I consider it obsolete now, along with earlier 144XL based ST536 builds.
The newer STE536 TOS (still WIP) is designed for the new ST536 builds and STE536 with the 288XL , which copies ROM into TTram. It wouldn't really make sense not to do that.
