Exxos's B-roll blog of nothing in particular
Re: Exxos's B-roll blog of nothing in particular
mrbombermillzy wrote: Mon Aug 25, 2025 6:30 pm Are you going to do the mod on this one?
Yeah probably.. its just getting around to it.. Need to do a couple month MPG tests as a baseline first though.. keep forgetting!
rubber_jonnie wrote: Mon Aug 25, 2025 6:32 pm Not sure your MPG will be anything half decent with an air filter like that...
Poor engine must be wheezing like a good un!!!
Yeah be interesting to see if it has a bit more power now...
exxos wrote: Mon Aug 25, 2025 6:34 pm
Updates are expected :)
rubber_jonnie wrote: Mon Aug 25, 2025 6:42 pm Updates are expected :)
:2k2:
Sofa bed broke again :roll: Metal just so thin its stupid as its a support bar !
Bought a cheap MIG welder off evilbay. The old welder I have just isn't any good. So hope the new one will be easier to use.
I also have a block of wood under the frame now taking the weight. Will likely just leave the blocks there. So even if my welding is bad, which it probably will be, at least it should help stop the frame from twisting as much.
.. and yes, girlfriend is very messing dropping crumbs down the side of the sofa it seems!! :roll: I'm sure a few sparks from the arc welding will burn those right up though !
Brings back memories of your welding if the office chair. Try not to set everything on fire :lol:
PhilC wrote: Mon Sep 08, 2025 4:44 pm Brings back memories of your welding if the office chair. Try not to set everything on fire :lol:
:D Yeah my chair is still fine :)
exxos wrote: Mon Sep 08, 2025 4:50 pm
Even if it is slightly scorched...
:fire1:
Don't see many of these visiting the garden these days....
Snap!
And better than one of these I spotted the other day.
