This is incorrect, the drive can be DS0 or DS1, it is a drive ID, you can't have both soldered at the same time.
Which jumpers are you specifically referring to, those on the drive itself or D0 and D1 on the small PCB?
There shouldn't be any need.. The GALs are all tested, so unless it was plugged in backwards should be fine.
I don't know.. but I also don't know why you need to know ? All the GALs are code protected, you can't read its contents anyway.bbisi wrote: Fri Jul 11, 2025 9:40 am is it correct that the gal only data begins from address 05835 to 0592
