Have you reseated the ROMs and the keyboard controller chip as well? And cleaned them of course?
You could also try swapping the chips with one of the board that is working.
Easy thing to try first.
BOOKMARK THIS PAGE !
STacy Memory Board
Darklord
Re: STacy Memory Board
Well... :)
"I removed, cleaned and reinstalled the socketed chips but
that made no difference."
"I then replaced the socketed chips with known working ones
from another board and that also made no difference."
Thanks.
Thanks.
DoG
Really sorry. I clearly didn't read. :oops:
Could be the PZIP RAM that is soldered in then.
Darklord
Hey, no worries mate. I'm sure you've seen how many times I didn't read,
or misread things in this forum (as well as others). I probably hold the
record. :lol:
record. :lol:
Users browsing this forum: CCBot and 11 guests
