330 disable function bug
68030 + SDRAM + IDE
supaduper
Re: 330 disable function bug
Post by supaduper »
Mister_Grave wrote: Sat Jan 25, 2025 11:17 am I just took the test. The tf330 remains activated.
So It now works with jumper in the Active position? and when you put the jumper on the DISABLE position it disables the TF330 from the CD32 ?
Mister_Grave
Post by Mister_Grave »
No. The problem is that I can no longer deactivate it.
supaduper
Post by supaduper »
Clean the Jumper pins with alcohol and try it again
disabled jumper position below
TF330 Disable jumper pic.jpg (183.85 KiB) Viewed 420 times
Mister_Grave
That's the first thing I did. I also recleaned all the contacts on the card as well as the riser.
supaduper
Post by supaduper »
Then that is a puzzle, if it has the correct firmware posted in this thread it should work, can you reflash the board yourself ? or know someone who can do it for you
Mister_Grave
I theoretically have everything I need to do it: I have Jtag cables, I have a pi4 (which serves as a Home assistant). It's just a bit laborious...
If the firmware was bugged, the tf330 wouldn't work at all, right?
supaduper
Post by supaduper »
Its the only thing I can suggest to see if it works with a reflash
Mister_Grave
Ok.... Is there a simple tutorial?
supaduper
Post by supaduper »
32bits did a nice pi tutorial
Mister_Grave
Thank you !
And last question, does the Firmware you are offering here contain the latest performance boost improvements?
Return to “TF330”
