DO NOT USE DEVICES WHERE THE IP CHANGES CONSTANTLY!
At this time it is unfortunately not possible to white list users when your IP changes constantly.
CURRENT PROTOTYPE STATUS (SEC 64MHz 68000)
Information and news about the 68SEC000 64MHz booster.
Re: CURRENT PROTOTYPE STATUS (SEC 64MHz 68000)
The PCB is still at the PCB company. So found the buffers are in 2 different size packages :roll: Got them to order the other types which will hopefully fit. Just they are sooooooo slow to get anything done. :roll:
Just got this image from fab :D
172854 (1) (1).png (837.71 KiB) Viewed 3229 times
Methanoid
Post by Methanoid »
is this canned now the ST536 is out? No posts in 2 years?
zfrenchy
Post by zfrenchy »
AGrred, what the status of the project, is it abandoned ?
I made some benchmark at the RAM is the slower in the STE
zfrenchy wrote: Sun Nov 30, 2025 3:46 am AGrred, what the status of the project, is it abandoned ?
I just don't have time to work on it at the moment but with the 536 being a better accelerator, it really is questionable if it's worth continuing anyway. It was mostly just an experiment to get the fastest 68k system. But with its intention being for the phoenix platform and it's having upgrades very slowly anyway.. The SEC CPU will likely move to that project, but won't be a standalone accelerator.
Thanks, great tests! it would probably be better if you put it in the benchmark section and explain exactly what the tests were.
I'm locking this thread as I don't plan to work on this project for the foreseeable future.. To many projects soaking up my time as it is.
Locked
Return to “SEC 64MHZ BOOSTER”
