RGB2HDMI mod for the Atari STacy
Darklord
Post by Darklord »
I had a few people ask if the RGB2HDMI mod for the ST also allowed mono (hi-res) mode. It does, and in the pictures below you can see it in action. On the ST, simply grounding pin #4 on the video port causes it to go into mono/hi-res mode (assuming your display can handle it). Adding a simple mini-toggle switch gives you the easy ability to switch back and forth between color and mono modes (after a reboot). So my STacy can now do lo-res, medium-res and hi-res. Yay! :)
Darklord
Re: RGB2HDMI mod for the Atari STacy
Post by Darklord »
Oh, here's some pictures of medium resolution as well:
(Yes, with the RGB2HDMI mod you can run -2- screens at once!)
Post by HigashiJun »
Nice !
Very nice.
:bravo:
Darklord
Post by Darklord »
BTW, here is what you get if you leave your SC1224 plugged into the external color monitor port on the STacy,
while running in hi-res mode. :roll:
@Darklord
And there's no workaround ?
Darklord
Post by Darklord »
HigashiJun wrote: Sat Nov 30, 2024 5:24 am @Darklord
Honestly, I'm not sure. It's not unexpected. After all, the SC1224 is a color
monitor that only handles low and medium resolutions.
I'm sure if you plugged an SM124 monitor into the external monitor port it
(the STacy screen) would work fine, but I don't have one.
The SC1224 works fine plugged in as long as the STacy is in low or medium
resolution.
Apparently, you just can't "mix and match". :)
Yes, it makes sense.
Darklord
Post by Darklord »
I've not tried it just yet (but will later some time), but I'm betting my
Dell 27" monitor with the UBE style VGA adapter will work fine with
all 3 ST resolutions from the STacy's external monitor port.
Will report back when I do.
