This arrived in the post yesterday - PC Engine & CD-ROM 2
Re: This arrived in the post yesterday - PC Engine & CD-ROM 2
Any luck with the HuCard today @PhilC ?
- HigashiJun
@rubber_jonnie
Please be patient !
Yes the card has just arrived, so a quick snooze for an hour and then I'll be plugging it in.
The new CD-ROM gear arrived as well as the controller, so got my fingers crossed.
Hahaha
Ooooh, how excitingPhilC wrote: Fri Oct 18, 2024 12:58 pm![]()
- HigashiJun
Good news !
And fingers crossed for you.
And the first bit of news is:
I'll work on the CD drive next but happy that my guess of the light blue screen meant unable to read or no HuCard present.
PhilC wrote: Fri Oct 18, 2024 2:25 pm And the first bit of news is:
The second but if news is that the CD drive also works but has a spindle height issue, so that will need to wait until I have a CD to try in it (no rush) and I suspect it needs a CD HuCard, which hopefully with the SD solution arriving soon, will sort that out.
If you need any of the CD HuCards, I have a bunch of them that work with my SD card solution, just shout.PhilC wrote: Fri Oct 18, 2024 2:47 pm The second but if news is that the CD drive also works but has a spindle height issue, so that will need to wait until I have a CD to try in it (no rush) and I suspect it needs a CD HuCard, which hopefully with the SD solution arriving soon, will sort that out.
I think the spindle height was a fairly common issue, at least on the Duo R. Just be careful as it's a press fit on the motor and a pain to move even a little bit.
How are you enjoying R-Type?
