I'm a glutton for punishment - Another Electron to dance with...
Re: I'm a glutton for punishment - Another Electron to dance with...
Let's hope it's a case of plugging the new ICs in and then off you go. What were the faulty ones? I seem to go through 74157s and 257s at the mo
So far it's been: 74LS273, 74LS00, 74LS10, 74LS20, 74LS04, 74LS32 and 74LS139.PhilC wrote: Wed Aug 21, 2024 3:30 pm Let's hope it's a case of plugging the new ICs in and then off you go. What were the faulty ones? I seem to go through 74157s and 257s at the mo
Given that there are only 14 LS IC's it's not a good look...
Well the last of my replacement IC's arrived today and the result is a fully working Plus 1
*HELP reveals all the ROM extensions and it works great with my ELKSD Plus1:
The Joystick port works just fine.
Looks great retrobrited too
And here are the culprits:
Out of 14 74LS ICs on the board, 7 are dead or partially dead. Seems like going swimming is not a good thing for a Plus 1 to do.
Happy to have it fixed and working
Yay! TTL carnage.
I'd go with apocalypse, but carnage works too...
One final thing. I upgraded the Plus 1 ROM from here: Plus 1 Enhanced ROM
Was a bit of a fiddle, I was told I should burn 4 copies across a 27C256, however I didn't twig that the ROM did not end on a boundary so I ended up with 3 copies slightly off from where they should have been.
Once I realised and erased the EPROM, I built a new image with each copy padded so that they would start at the correct location, and it works just fine now:
I'll keep the original safe just in case, though I have backed it up regardless.
I've attached the ROM image in case anybody else needs it.
- Attachments
- AP6v133x4_Padded.rom.txt
- (32 KiB) Downloaded 14 times
