Video driver thoughts
Re: Video driver thoughts
Yes, that's a good idea, probably only needed for the bit 3 and 4 as after that the increase will be very small.
At last, an opportunity for a triple decker. Now do I put it over or under the ram board
Don't follow what you mean ?Forgottenmyname wrote: Fri Oct 19, 2018 9:26 pm At last, an opportunity for a triple decker. Now do I put it over or under the ram board![]()
Well I already have the shifter in the adaptor board for your ram expansion.exxos wrote: Fri Oct 19, 2018 9:30 pmDon't follow what you mean ?Forgottenmyname wrote: Fri Oct 19, 2018 9:26 pm At last, an opportunity for a triple decker. Now do I put it over or under the ram board![]()
oh yepForgottenmyname wrote: Fri Oct 19, 2018 9:37 pm Well I already have the shifter in the adaptor board for your ram expansion.
More of a final draft...
..with something like this...
I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
Are you doing this to eliminate any potential DC in the signal ?
I'm doing it because that what it says in the datasheet.... I to am not sure why the falcon is wired up differently..rpineau wrote: Fri Oct 19, 2018 9:56 pm I'm not sure about C1, C2 and C3 inline with RGB, the Falcon has 75 ohm resistors inline to match standard line impedance for video signals.
Works for me .. I think the datasheet is probable more accurate than what was done on the falcon
Hopefullyrpineau wrote: Fri Oct 19, 2018 10:12 pm Works for me .. I think the datasheet is probable more accurate than what was done on the falcon![]()
