Science Of Cambridge MK14 Replica build
Re: A future project - Science Of Cambridge MK14
Post by HigashiJun »
stephen_usher wrote: Fri Jul 26, 2024 1:41 pm Replace with a Traco?
+1
HigashiJun wrote: Sat Jul 27, 2024 12:49 am
+1
It's on order :)
Re: Science Of Cambridge MK14 Replica build
Good to hear that !
I had a Traco in my Oric Atmos and it was night and day compared to the old and burning hot LM.
8-)
Out of interest, which traco do you guys use? A lot of the 7805 equivalents only do 0.5 - 1.0 amp which is fine for a spectrum but not for other stuff.
PhilC wrote: Sat Jul 27, 2024 8:11 am Out of interest, which traco do you guys use? A lot of the 7805 equivalents only do 0.5 - 1.0 amp which is fine for a spectrum but not for other stuff.
I had a TSN 1-2450A in my Atmos.
And yes, it was 1 amp.
Thanks @HigashiJun
The one I've ordered is 1 amp, the Mk14 takes around 1/2 amp.
TSR 1-2450A
So, the Traco is installed in the MK14 now:
And the thermals look good:
The Traco is running at 39.4C and the item at 56.6C in front of it is one of the two Tesla PROMs holding the SCIOS operating system. With the 7805 installed with a large heatsink I was getting about double the temp of the Traco, and also I'm pulling about 100mA less with the Traco too, so definitely a good call to swap it out.
I would put an oscilloscope on the +5V rail as these switching DC-DC converters may produce ripple.
stephen_usher wrote: Sat Aug 03, 2024 9:49 am I would put an oscilloscope on the +5V rail as these switching DC-DC converters may produce ripple.
Maybe later on, just at the barbers for a trim 😁
EDIT - I'm seeing a mean ripple value of about 15mV, probably helps having a 1000uF capacitor on the input side.
