General Stuff(tm)
Re: General Stuff(tm)
Started on the case last night.
The first "fitting" prototype was promising, though needed significant tweaking. I should be able to get the first usable one done tonight though.
stephen_usher wrote: 16 Jul 2024 09:48 Started on the case last night.
Good stuff.
I hope the 3d printed case will be as beige as the OPD :)
I'll have to spray it as I've not got that colour at the moment. :-)
stephen_usher wrote: 16 Jul 2024 13:12 I'll have to spray it as I've not got that colour at the moment. :-)
:lol:
Aargh!
What fun! At work I'm trying to recover a 2019 vintage Dell Precision workstation with an Avago 9440-8i RAID controller which has lost its settings.
Going to the Dell documentation they say that they have "de-featured" the controller's BIOS and you have to set it up via a wizard in the UEFI BIOS.... Which you can only run once when the system is new and nothing installed (not even if Dell have set things up with an OS).
So, if there's an issue and you can't boot Windows and run the configuration program it's basically bricked.
Whoever thought removing the configuration system from the BIOS should have been fired with extreme prejudice!
BennehBoy
Post by BennehBoy »
Kind of make having a RAID volume pointless doesn't it.
I wonder if a linux live cd might help - more options possibly?
BennehBoy wrote: 16 Jul 2024 18:50 Kind of make having a RAID volume pointless doesn't it.
You'd have to be able to install the MegaRAID SAS package and even then it'd not help a great deal.
In previous versions you'd go into the RAID controller BIOS and tell it to import the "foreign" configuration, read from one of the disks, and it would be back to normal.
Made some progress with the floppy interface case.
I need to make the main body of the case about 2mm deeper and the lugs on the front "hatch" longer.
BennehBoy
Post by BennehBoy »
stephen_usher wrote: 16 Jul 2024 21:35 In previous versions you'd go into the RAID controller BIOS and tell it to import the "foreign" configuration, read from one of the disks, and it would be back to normal.
Can't understand why they would deprecate that, just plain daft.
Any option for a BIOS downgrade?
I actually just bought a P920 with dual gold 6148 xeons... turning up later this week. I likely will avoid any of the inbuilt RAID, I think's its mainly VROC biased anyway so since I have no intel SSD's probably not useful.
No chance as this is the original BIOS version Dell shipped on the adapter. (It's the adapter BIOS rather than the PC BIOS which has been hobbled.)
Users browsing this forum: apple [bot], ClaudeBot and 10 guests
