Exxos will like this colour of Switch Lite :)
I've been trying to pick up a Switch or Switch Lite for a while, not minding if it's spares/repair, but until now they've been a bit expensive, but I got this one:
And it was under £50. Under the grime and stickers, it's actually in extremely good condition, and I don't see any signs of liquid damage around the ports/sticks/buttons etc.
The main problem? No power, and looking into the USB C port it doesn't look good, so I have another on order. More updates when that arrives.
Re: Exxos will like this colour of Switch Lite :)
Post by HigashiJun »
Not shocking pink, but nice standard pink...
8-)
HigashiJun wrote: Sat Apr 06, 2024 1:41 pm Not shocking pink, but nice standard pink...
8-)
I'd say soft pink :)
exxos wrote: Sat Apr 06, 2024 2:23 pmPretty :)
I thought you'd like it :)
The replacement USB port arrived for the Switch Lite yesterday, so I have moved it to the workbench and started prepping.
Once you get the cover and heat/emi shield off, there are many screws, so I decided I'd need to be able to ID them all, so I used Sharpies to mark them in different colours so I'd know exactly where they needed to go back.
In addition, I used a ton of little pots to uniquely identify all the different modules and areas I was dealing with.
And with the mainboard finally out, I'm set up and ready to get the USB port off and drop a new one on.
The battery was flat as a pancake, so I'm confident it simply wan't charging, and there is visible damage in the port. Fingers crossed it's nothing more serious, and I may check for capacitor shorts around the board while I'm here.
It's mega clean inside and the liquid spill indicators are clear too, in fact no signs of liquid anywhere at all.
While you've got it open?
https://www.ebay.co.uk/itm/126347797875
Homebrew only of course
alexh wrote: Fri Apr 12, 2024 12:19 pm While you've got it open?
Well the port swap went fine, but I'm still not getting charge, so until I can get power to it I'll not be doing much else.
Annoyingly the flap on one of the connectors pinged off too, so I need to get one of them now as well :mad:
How far onto the board is the power getting now?
stephen_usher wrote: Fri Apr 12, 2024 1:10 pm How far onto the board is the power getting now?
I see 5v at a test point on the other side of the USB socket, and that works either way the USB connector is plugged in.
However, looking at the board with my thermal camera, the charging control IC, M92T36 is getting hot, enough to evaporate IPA, and everything else is cold. That IC is the charge control chip, so I have a suspicion it's dead.
They are reasonably cheap so I'll order one and in the meantime check around the old one for shorts. Apparently they are a common failure point.
EDIT - I have IC and a new connector on order. I hate those connectors, so damn fragile.
EDIT 2 - The M92T36 is shorted to GND, which is probably why it's not charging and has no power...
