I'm wondering if a simpler solution would be a short 13 pin din male to 13 pin din female cable that does the swapping around to allow for a standard cable to plug into that.
Can do the same on the floppy port and just leave them plugged in ready to accept a standard floppy/video cable without messing with the board?
Icky - Progress
Re: Icky - Progress
I don't think there will be, for a lot of people its not worth the postage from UK to USA, in particular as I order small stuff from USA to UK, shipping back to USA would take like 2 months round trip.Forgottenmyname wrote: 06 Oct 2018 16:53 I'm just waiting for the unf*ck section on the Exxos store :D
As for unf*ck, the "bad word" filter isn't turned on :)
Re: Icky - Progress
If you find that easier then for sure go with that :)PeteW wrote: 06 Oct 2018 17:37 I'm wondering if a simpler solution would be a short 13 pin din male to 13 pin din female cable that does the swapping around to allow for a standard cable to plug into that.
PeteW
Re: Icky - Progress
Even easier is to watch from a safe distance and just make stupid suggestions 😀 I'll go with that!
Re: Icky - Progress
Finally got the boarding on after a lot of messing around. Those pins are soooo annoying to get into the holes.
Now to un-f*ck my cable to test
Re: Icky - Progress
So what sort of height does the spacer need to be?
Re: Icky - Progress
The space for mine is 11mm which gives enough clearance from the RGB Buffer components. I did cut down the legs so it could of been up to 15mm.
EDIT: you could go down to 10mm so it between 10 - 15mm
PaulJ
Re: Icky - Progress
Yes, I'd love to solder the video connector on but the thought of unsoldering it makes me cringe.. :stickwhack: :stickwhack: :stickwhack: So I believe I'll wait for the Un-F*ck boards I ordered. :dizzy: :dizzy: I really HATE waiting.. :mad:
Re: Icky - Progress
I would recommend waiting. It will save messing around with cables and also stop you plugging the wrong ones in.PaulJ wrote: 06 Oct 2018 19:40 Yes, I'd love to solder the video connector on but the thought of unsoldering it makes me cringe.. :stickwhack: :stickwhack: :stickwhack: So I believe I'll wait for the Un-F*ck boards I ordered. :dizzy: :dizzy: I really HATE waiting.. :mad:
Re: Icky - Progress
On more adjustment today to clean up using the 32.084988 MHz crystal.
I had it with wires stuck into the socket for the crystal which was a bit of a mess hanging in mid air.
Created a DIL adaptor with a bit of wiring to wire down to the smaller socket.
Plus a little heat gun action to keep it in one block so I can easily plug in and out.
Had to lie the R915 flat out of the way.
