Thanks
A blast from the past sort of - Altairduino build.
Re: A blast from the past sort of - Altairduino build.
Well, busy day. First sorting out the battery in my wife's car. Halfords were great and even gave me an upgraded replacement as they didn't have the same one in stock, and no fuss, no messing, just replaced under warranty.
Then I had to get some keys cut, something I'd been putting off for a while. Then it was time for some more building!!!
This time it was the casework
This is me getting started after finishing peeling the plastic and paper off the laser cut acrylic parts, one of my least favourite things to do.
Firstly sub assemblies:
Eventually putting everything together into one whole case:
Then adding in the front panel exectronics:
And finally finishing off with the final flourish of the front trim panel:
It's not a bad analogue of the original:
Though obviously smaller and without the metal case.
Very happy with the results so far, but while it is technically usable, I am still waiting on the expansion board PCB that was missing from my kit (All the other parts were there though) and it's in transit, so I will do a build of that and install separately when it arrives
I'm determined to program it from the front panel, even just something tiny, so need to do some research
- HigashiJun
I now feel like getting one too...
Am I going to end up being responsible for one of your purchases...
Very good kit though
- HigashiJun
Do worry not, my fellow forum member !rubber_jonnie wrote: Sat Mar 02, 2024 8:50 pm Am I going to end up being responsible for one of your purchases...
Very good kit though![]()
There are times when reason has the edge over passion, and this time the reason is called "my wife"...
Yes, that reason can also be found operating around the globeHigashiJun wrote: Sun Mar 03, 2024 3:45 amDo worry not, my fellow forum member !rubber_jonnie wrote: Sat Mar 02, 2024 8:50 pm Am I going to end up being responsible for one of your purchases...
- HigashiJun
Some reasons seem to be more tolerant however...rubber_jonnie wrote: Sun Mar 03, 2024 9:34 am Yes, that reason can also be found operating around the globe![]()
Well, if she ever becomes wife 1.0 and enters the beta testing phase, you may need to adjust your expectationsexxos wrote: Sun Mar 03, 2024 1:13 pmmy girlfriend doesn't care what I do as long as I don't touch her stuff... But she's not currently my wife... She's still on trial/ probation / Alpha testing...
To be fair, my wife is pretty flexible, and if I get an annual bonus from work I am always able to spend a portion of it. Personally I do have an inbuilt gauge about what I think is too much, so it works pretty well
