PS3 part deux
Re: PS3 part deux
:shock: :shock: that came from a pet household fur-sure :lol:
Re: PS3 part deux
exxos wrote: Mon Dec 11, 2023 3:12 pm :shock: :shock: that came from a pet household fur-sure :lol:
:dizzy:
Re: PS3 part deux
Doing some research it seem that one of the potential causes of the problem is bad Tokin capacitors. They are low profile large devices and there are at 8 on my board, 4 on top, 4 underneath:
I warmed up the 2 that sit under the GPU and it now boots. It's not quite right, but is suggestive that it would be worth doing a Tokin replacement, so I will order a couple of cap kits now and do the two below the GPU that I warmed up and see what happens.
Re: PS3 part deux
Progress at least.
Re: PS3 part deux
stephen_usher wrote: Thu Dec 14, 2023 11:52 am Progress at least.
Indeed, and a relatively cheap option to try. If after replacement it boots without an image on-screen I'll have to consider reflowing the GPU.
Re: PS3 part deux
So the caps arrived today, more from Zedlabz, who I am beginning to rather like as a supplier.
In total, you need 4 caps (470uF low ESR) per Tokin. Don't be under any illusion the the Tokins will just lift off with a bit of heat, because the ground and power planes are huge, so need quite a bit of heat, and the Tokins are not solid, in fact even a little heat and the top cover comes off like the lid of a box.
So it's a case of using a combination of soldering iron, hot air, and a pair of tweezers to pick everything away. Once cleaned up, rather than put the new caps at an angle as some do, I decided to put them straight, and that meant cleaning up the large ground trace a bit further back from the original pad, but it was easy to do with a fibreglass pencil.
I tinned the +ve pads of the caps and the board, and soldered in that end of the cap, leaving a big enough gap between the ends of the caps to get in with a heavy chisel tip on my soldering iron for the -ve ends.
I had to set the iron to max and use a bit of hot air, but it eventually it soldered up nicely.
This is the end result:
You can see the other Tokins under the CPU (There are another four on the other side of the PCB), but I was lucky, because they weren't needed and the PS3 powered on just fine!!!
I was all ready to give the GPU a reflow, but it just works, so just makes me wonder how many PS3s have been scrapped like this, it's really not a difficult fix if you can solder and have the patience to pick off the old Tokins bit by bit.
To satisfy all the wonderers out there, I put down some solder mask on the exposed areas to prevent corrosion.
For some reason the DVD drive wasn't spinning up, but after a bit of a clean, it's all good now and works just fine.
Re: PS3 part deux
:girldance: :girldance: :girldance: :cheer: :cheer: :cheer: :yay2: :yay2: :dualthumbup: :dualthumbup: :2k2:
Re: PS3 part deux
stephen_usher wrote: Sat Dec 16, 2023 4:35 pm :girldance: :girldance: :girldance: :cheer: :cheer: :cheer: :yay2: :yay2: :dualthumbup: :dualthumbup: :2k2:
Hehehehe
Re: PS3 part deux
Post by HigashiJun »
:girldance: :cheer: :yay2: :girldance: :cheer: :yay2: :girldance:
Well done !
Re: PS3 part deux
HigashiJun wrote: Sun Dec 17, 2023 3:14 am :girldance: :cheer: :yay2: :girldance: :cheer: :yay2: :girldance:
Well done !
:cheers:
