The Floppy Disk Interface can be divided into three sections: Motor Control, Write Signals and Read Signals. All of these lines are capable of driving one TTL load and not compatible for direct connection to the drive. Most drives require an open-collector TTL interface with high current drive capability. This must be done on all outputs [...].
Icky - Progress
Re: Icky - Progress
From a WD floppy disk controller IC application note:
Re: Icky - Progress
From the BBC Master. The quality is poor, but notice a WD1772 and 7406 buffers:
Re: Icky - Progress
Thanks I didn't see any mention of IO buffers... It seems its the 1K pull up being the main issue. Though 40mA pull down on the LS06, vs 16MmA on a 04.. drives must need a lot of IO juice...czietz wrote: Thu Sep 27, 2018 11:37 am The Floppy Disk Interface can be divided into three sections: Motor Control, Write Signals and Read Signals. All of these lines are capable of driving one TTL load and not compatible for direct connection to the drive. Most drives require an open-collector TTL interface with high current drive capability. This must be done on all outputs [...].
Re: Icky - Progress
Back to the plot...exxos wrote: Thu Sep 27, 2018 10:24 am It might be worth scoping out some pins around ACIA area, such as (U54) A1 pin 11, A2 pin 8, (U32) pin 3 SNDCS.. (IC2 MFP) pin 48 CS.
My thoughts here are the chip select lines having noise on them causing the ACIA,YM etc not to be selected properly..
It is only a theory. Though I mention it as the GLUE on the original STFM is basically in the centre of the motherboard so the signals are not going as far to the chips on those boards...
However on the remake board, the GLUE about as far away from the ACIA,YM etc as it could possibly be.. So I am making the assumption that the signals have some noise is causing the odd issues..
So if someone can scope out the signals and upload them, then it will help..
Worst case with this issue is just adding some resistors in series with the CS signals.. Though I pretty much already anticipated this problem..
Re: Icky - Progress
Just wired the drive in on mine. It's detected but doesn't work. The disk activity light stays on, like the cable is the wrong way round.
Using one of your 1.44mb drives.
Anything obvious you can think of?
Re: Icky - Progress
Have you put the cable in upside down ? still need to do that...Forgottenmyname wrote: Thu Sep 27, 2018 5:24 pm Just wired the drive in on mine. It's detected but doesn't work. The disk activity light stays on, like the cable is the wrong way round.
Re: Icky - Progress
Yes I did but it doesn't detect the drive then
Re: Icky - Progress
can you try a 720 drive ?
Re: Icky - Progress
Yes, I tried the one from my Mega and another from the STFM, both the drive lights stay on with cable one way and the other way the drive is not detected.
Just checked connections between 1772 and LS06 and they seem to be ok so far.
Re: Icky - Progress
Have to check pin 20 of the 1772 (motor on) and see if its doing anything... I dont know offhand if it goes high or low, but after desktop it should switch as normally the motor turns off once it gets to desktop.Forgottenmyname wrote: Thu Sep 27, 2018 6:06 pm Yes, I tried the one from my Mega and another from the STFM, both the drive lights stay on with cable one way and the other way the drive is not detected.
Might also be worth testing the DMA, 1772, YM chip in your MEGA and make sure they work OK in another machine..
