3D printer globby direction changes ?
Re: 3D printer globby direction changes ?
@rubber_jonnie that's what linear advance is supposed to do. Though it just ends up with gaps before the blobs :roll:
I was just messing with Cura, but think maybe just going for pure infill rather than shells would be better.
exxos wrote: Fri Oct 13, 2023 11:30 am @rubber_jonnie that's what linear advance is supposed to do. Though it just ends up with gaps before the blobs :roll:
Yeah, I think the 20mm wall thickness is the problem, it's just laying down so much plastic, the slowdown at the corner is causing a bulge and the linear advance you mentioned isn't coping well.
If you only intend for it to be a template for a metal part, so you can test fit before having it made, then pure infill would probably do the job.
rubber_jonnie wrote: Fri Oct 13, 2023 11:34 am Yeah, I think the 20mm wall thickness is the problem, it's just laying down so much plastic, the slowdown at the corner is causing a bulge and the linear advance you mentioned isn't coping well.
Yep. Though I will round the corners to see what that does. I will likely have to print another. Current one been running a hour already and its a 4-5 hour print. So don't want to keep stopping it.
Rounding corners may help but it is still sharp turns on the internals anyway :roll:
I guess the likely lesson here is, don't print squares on the 3-D printer :lol: :roll:
Return to “CHAT FORUM PUBLIC”
