I marked on red where the blobs are happening.
The head slows down the changing direction so you would think extrusion is still happening causing it to blob up. The problem is I cannot actually find a cause
If I reduce the head temperature makes no odds. If I fiddle with the linear advance all it does is start creating gaps before the blobs. Changing printer speed or acceleration has no effect either. I even tried 1mm coasting at the end of the lines. Made no odds.
So there does not seem to be any setting to prevent this ?!
